Error when add a node
When i create a node i have a message :
[oneadmin@localhost ~]$ onehost create -i xen -v xen -n dummy
[HostAllocate] User couldn’t be authenticated, aborting call.
Log:
Fri May 15 17:22:48 2015 [ReM][D]: Req:1776 UID:- HostAllocate invoked, “x.x.x.x”, “xen”, “xen”, “dummy”, -1
Fri May 15 17:22:48 2015 [ReM][E]: Req:1776 UID:- HostAllocate result FAILURE [HostAllocate] User couldn’t be authenticated, aborting call.
Fri May 15 17:22:55 2015 [ImM][I]: --Mark–
Fri May 15 17:22:55 2015 [InM][I]: --Mark–
Fri May 15 17:22:55 2015 [VMM][I]: --Mark–
Fri May 15 17:22:57 2015 [ReM][D]: Req:2304 UID:- VirtualMachinePoolInfo invoked, -2, -1, -1, -1
Fri May 15 17:22:57 2015 [ReM][E]: Req:2304 UID:- VirtualMachinePoolInfo result FAILURE [VirtualMachinePoolInfo] User couldn’t be authenticated, aborting call.
Fri May 15 17:23:10 2015 [InM][D]: Monitoring datastore default (1)
Fri May 15 17:23:10 2015 [InM][D]: Monitoring datastore files (2)
Fri May 15 17:23:10 2015 [ImM][D]: Datastore default (1) successfully monitored.
Fri May 15 17:23:10 2015 [ImM][D]: Datastore files (2) successfully monitored.
Any idea whats happen?
thanks
Did you change any passwords, or any of the auth files located in /var/lib/one/.one/?
thanks…yes i change password but now its ok
