ESX VM shutdown failed - undefined method 'poll' (NoMethodError)
Hello!
I am trying to shutdown ESX VM and getting the following error about undefined method “poll”:
Fri May 22 14:48:00 2015 [Z0][LCM][I]: New VM state is SHUTDOWN
Fri May 22 14:48:21 2015 [Z0][VMM][I]: Command execution fail: /var/lib/one/remotes/vmm/vmware/shutdown ‘one-44’ ‘neb-zoo-15.domain’ 44 neb-zoo-15.domain
Fri May 22 14:48:21 2015 [Z0][VMM][I]: /var/lib/one/remotes/vmm/vmware/shutdown:47:in <main>': undefined methodpoll’ for #VMwareDriver:0x00000001a165e8 (NoMethodError)
Fri May 22 14:48:21 2015 [Z0][VMM][I]: ExitCode: 1
Fri May 22 14:48:21 2015 [Z0][VMM][I]: Failed to execute virtualization driver operation: shutdown.
Fri May 22 14:48:21 2015 [Z0][VMM][E]: Error shutting down VM
Fri May 22 14:48:21 2015 [Z0][LCM][I]: Fail to shutdown VM. Assuming that the VM is still RUNNING (will poll VM).
Fri May 22 14:48:22 2015 [Z0][VMM][I]: VM running but monitor state is POWEROFF
Fri May 22 14:48:22 2015 [Z0][DiM][I]: New VM state is POWEROFF
How to fix?
Thanks!
Mikhail
p.s. OpenNebula - 4.12.1, ESX 5.5.0
This seems to be a bug. Could you please try setting a modified shutdown (2.2 KB) script in /var/lib/one/remotes/vmm/vmware and try again?
Hello!
Cannot download the file.
Got error: The page you requested doesn’t exist or is private.
Mikhail
Hi, Tino!
Please re-upload modified shutdown script.
I did’t get it before sandbox re-creation …
Thanks!
Mikhail
Please find it in this gist:
https://gist.github.com/tinova/c5944e6819a4f42911ae
Hi!
It worked!. VM is correctly shuts down for now.
It is time to patch distro :wink:
Thanks!
Mikhail
