rvalle
(Rafael)
#1
I can successfully use EthernetAddress reservations and get assigned to interfaces during contextualization.
This is an important feature to administer public IPs.
What I don’t see is how to setup DHCP on that interfaces. Is there support for it during contextualization? is it done with a script?
rvalle
(Rafael)
#2
After researching a bit, looks like the easiest would be one of:
- patch in a modified networking context script
- run a workaround script that will fix the interface
considering that it is also possible to upload files during contextualization, seems like 1 is the best option.
Just guessing…
