My fireedge key isn’t generating on startup. Is there a way to manually trigger that ?
Hello @nicpon ,
Fireedge key should be generate once the server is initialized. Maybe, you could check the fireedge.log
/fireedge.error
to debug the error.
In any case, you can create the key manually with:
echo "random_key" >> /var/lib/one/.one/fireedge_key
In HA environments, you can read the doc for more information:
https://docs.opennebula.io/6.0/installation_and_configuration/opennebula_services/fireedge.html?highlight=fireedge_key#configuration
Cheers,
Sergio
Thanks that worked.
