Hostname Error in FireEdge
We are unable to create on-prem provision. We created a On-Prem provider and when we try to provision using that provider the following error occurs:
Although we give all the hostnames in the following manner:
OpenNebula Version: 6.0.0.2
Hi @Nikhil_Kumar,
The provision templates are designed to use from the CLI and FireEdge GUI, however that type input (array) contains a mismatch. In future releases, this will be change.
All you should to do is press ENTER key once you enter a value. FireEdge takes care of separating your list by commas.
In any case, you can read more information about Edge Cluster management in OpenNebula documentation.
Best,
Sergio
Hello @sbetanzos
Thanks a lot. It worked.
