Yes, maybe my explanation was not clearly, let me give you a little bit more details about my ideas…
Architecture
- 7 Physical servers
– 1 Sunstone
– 6 Nodes
The 7 servers are connected to internet thru physical switch. Each server has a single NIC.
Networking
- One of the VLAN must have Internet connection.
- I want to split the network traffic by VLANS, each VLAN will carry the traffic of a group of VM.
At this time, my configuration that only works is:
- Internet connection in the physical servers thru OVS.
Issues:
If I try to reach internet thru my VM I can´t… I did a dump in my VM and it tries to reach the GW, as far as I know the flow should be something like this…
VM → GW → OVS → OVS Bridge → Internet
I did the changes that you suggest me… about the IP range but still it is not working… Could you help me to setup correctly my network? I feel that my problem is in my virtual network configuration…
Thanks… ![]()
