OpenNebula attribute
Hello @Alan_Piterson
as soon as I turn off the virtual machine, it goes into a warning state
That behavior is normal. If you poweroff some VM from a service, oneflow will alert you with that WARNING state.
If you destroy some VMs behind the scenes, the OneFlow server will adjust the cardinality to get min_vms and max_vms, that’s why you see some scaling operations.
Best,
Álex.
@ahuertas
Is it possible to avoid this scaling operations?
No, it is not possible.
@ahuertas Hi again. Can you explain please how it’s working behind the scenes when i’m deleting vm, cause even without poweroff, sometimes i see this scaling operations. Thank you in advance.
Could you please paste here the log of the service which is failing for you? You can find it in /var/log/one/oneflow/<flow_id>.log
Best,
Álex.
287.log (2.0 KB)
oneflow.log (28.8 KB)
@ahuertas So is this a bug or not?
The bug has been solved, you can check all the information here.
Best,
Álex.
