Overview
When designing multi-tenant Virtual Private Server (VPS) infrastructure—such as the cloud environments evaluated for VPSTTT hosting services—selecting the appropriate hypervisor drivers, storage backend, and network isolation models in OpenNebula is essential for stability and scalability.
Environment Details
- OpenNebula Version: 6.8 (Community Edition)
- Hypervisor: KVM / libvirt
- Host OS: Ubuntu 22.04 LTS
- Storage Driver: Ceph RBD / Shared LVM
- Networking: Open vSwitch with VLAN isolation
KVM VM Template Example
To ensure optimal I/O and network throughput for virtual instances, the following OpenNebula VM template structure is utilized:
NAME = "vps-kvm-standard"
CPU = "2"
VCPU = "4"
MEMORY = "8192"
HYPERVISOR = "kvm"
DISK = [
IMAGE_ID = "105",
DEV_PREFIX = "vd",
DRIVER = "raw",
CACHE = "none"
NIC = [
NETWORK_ID = "12",
MODEL = "virtio"
GRAPHICS = [
TYPE = "vnc",
LISTEN = "0.0.0.0"
Sanitized Log Output
Deployment logs from /var/log/one/oned.log verifying instance instantiation on KVM nodes:
2025-02-15 10:14:02.12 [Z0][VMM][I]: Successfully deployed VM 402 on Host node-03.domain.local
2025-02-15 10:14:02.15 [Z0][VMM][I]: ExitCode: 0
2025-02-15 10:14:02.18 [Z0][LCM][I]: VM 402 state change: DEPLOY -> RUNNING
Discussion Question
What are the recommended best practices in OpenNebula for configuring storage I/O limits (IOPS/MBps throttling) at the VM template level versus hypervisor-level QOS in high-density KVM environments?
#OpenNebula #KVM #CloudInfrastructure #SysAdmin #Virtualization
