I attach generated logs when user #103 (GID #102) opens a VNC session from user #234 (GID #104) and vice versa:
Logs generated when user #103 opens a VNC session of a VM owned by user #234:
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: Request #103 USER/#103 USE #0
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: > Rule * USER/#103 #0
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: > Rule * ZONE/* USE *
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: > Rule * MARKETPLACE+MARKETPLACEAPP/* USE *
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: > Rule #103 USER/#103 USE+MANAGE #0
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: Permission granted
Fri Oct 23 08:59:36 2026 [Z0][ReM][D]: Req:7200 UID:103 one.user.info result SUCCESS, "<USER><ID>103</ID><G..."
Fri Oct 23 08:59:36 2026 [Z0][ReM][DD]: Number of active connections: 1
Fri Oct 23 08:59:36 2026 [Z0][ReM][DD]: Number of active connections: 2
Fri Oct 23 08:59:36 2026 [Z0][ReM][D]: Req:4032 UID:103 IP:127.0.0.1 one.user.info invoked , -1, false
Fri Oct 23 08:59:36 2026 [Z0][ReM][D]: Req:4032 UID:103 one.user.info result SUCCESS, "<USER><ID>103</ID><G..."
Fri Oct 23 08:59:36 2026 [Z0][ReM][D]: Req:6800 UID:103 IP:127.0.0.1 one.group.info invoked , 102, false
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: Request #103 GROUP/#102 USE #0
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: > Rule * GROUP/#102 #0
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: > Rule @102 GROUP/#102 USE #0
Fri Oct 23 08:59:36 2026 [Z0][ReM][D]: Req:6800 UID:103 one.group.info result SUCCESS, "<GROUP><ID>102</ID><..."
Fri Oct 23 08:59:36 2026 [Z0][AuM][D]: _authenticate: -
Fri Oct 23 08:59:36 2026 [Z0][ReM][D]: Req:2896 UID:1 IP:127.0.0.1 one.system.config invoked
Fri Oct 23 08:59:36 2026 [Z0][ReM][D]: Req:2896 UID:1 one.system.config result SUCCESS, "<OPENNEBULA_CONFIGUR..."
Fri Oct 23 08:59:36 2026 [Z0][ReM][D]: Req:8416 UID:103 IP:127.0.0.1 one.grouppool.info invoked
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: Reverse search request #103 GROUP/* USE #0
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: > Rule @102 NET/* USE #0
Fri Oct 23 08:59:36 2026 [Z0][ACL][DD]: > Rule @102 DATASTORE/* USE #0
Fri Oct 23 08:59:36 2026 [Z0][ReM][D]: Req:8416 UID:103 one.grouppool.info result SUCCESS, "<GROUP_POOL><GROUP><..."
Fri Oct 23 08:59:37 2026 [Z0][ReM][DD]: Number of active connections: 1
Fri Oct 23 08:59:37 2026 [Z0][ReM][DD]: Number of active connections: 2
Fri Oct 23 08:59:37 2026 [Z0][ReM][D]: Req:8704 UID:103 IP:127.0.0.1 one.system.version invoked
Fri Oct 23 08:59:37 2026 [Z0][ReM][D]: Req:8704 UID:103 one.system.version result SUCCESS, "7.0.1"
Fri Oct 23 08:59:37 2026 [Z0][AuM][D]: _authenticate: -
Fri Oct 23 08:59:37 2026 [Z0][ReM][D]: Req:5296 UID:1 IP:127.0.0.1 one.user.info invoked , 103, true
Fri Oct 23 08:59:37 2026 [Z0][ReM][D]: Req:5296 UID:1 one.user.info result SUCCESS, "<USER><ID>103</ID><G..."
Fri Oct 23 08:59:37 2026 [Z0][ReM][D]: Req:3760 UID:1 IP:127.0.0.1 one.vm.info invoked , 8956, true
Fri Oct 23 08:59:37 2026 [Z0][ReM][D]: Req:3760 UID:1 one.vm.info result SUCCESS, "<VM><ID>8956</ID><UI..."
Fri Oct 23 08:59:37 2026 [Z0][ReM][D]: Req:4240 UID:103 IP:127.0.0.1 one.vm.info invoked , 8956, false
Fri Oct 23 08:59:37 2026 [Z0][ACL][DD]: Request #103 VM/#8956 USE #0
Fri Oct 23 08:59:37 2026 [Z0][ACL][DD]: > Rule * VM/#8956 #0
Fri Oct 23 08:59:37 2026 [Z0][ACL][DD]: > Rule * ZONE/* USE *
Fri Oct 23 08:59:37 2026 [Z0][ACL][DD]: > Rule * MARKETPLACE+MARKETPLACEAPP/* USE *
Fri Oct 23 08:59:37 2026 [Z0][ACL][DD]: > Rule @102 HOST/* MANAGE #0
Fri Oct 23 08:59:37 2026 [Z0][ACL][DD]: > Rule @102 NET/* USE #0
Fri Oct 23 08:59:37 2026 [Z0][ACL][DD]: > Rule @102 DATASTORE/* USE #0
Fri Oct 23 08:59:37 2026 [Z0][ACL][DD]: > Rule @102 VM+TEMPLATE/* CREATE *
Fri Oct 23 08:59:37 2026 [Z0][ACL][DD]: No more rules, permission not granted
Fri Oct 23 08:59:37 2026 [Z0][ReM][E]: Req:4240 UID:103 one.vm.info result FAILURE [one.vm.info] User [103] : Not authorized to perform USE VM [8956].
Last two lines:
- [Z0][ACL][DD]: No more rules, permission not granted
- [Z0][ReM][E]: Req:4240 UID:103 one.vm.info result FAILURE [one.vm.info] User [103] : Not authorized to perform USE VM [8956].
But permission is granted as you can see in browser tab:
And logs generated when user #234 opens a VNC session of a VM owned by user #103:
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: Request #234 USER/#234 USE #0
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: > Rule * USER/#234 #0
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: > Rule * ZONE/* USE *
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: > Rule * MARKETPLACE+MARKETPLACEAPP/* USE *
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: > Rule #234 USER/#234 USE+MANAGE #0
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: Permission granted
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:9296 UID:234 one.user.info result SUCCESS, "<USER><ID>234</ID><G..."
Fri Oct 23 09:00:52 2026 [Z0][ReM][DD]: Number of active connections: 1
Fri Oct 23 09:00:52 2026 [Z0][ReM][DD]: Number of active connections: 2
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:5568 UID:234 IP:127.0.0.1 one.user.info invoked , -1, false
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:5568 UID:234 one.user.info result SUCCESS, "<USER><ID>234</ID><G..."
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:4432 UID:234 IP:127.0.0.1 one.group.info invoked , 104, false
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: Request #234 GROUP/#104 USE #0
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: > Rule * GROUP/#104 #0
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: > Rule @104 GROUP/#104 USE #0
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:4432 UID:234 one.group.info result SUCCESS, "<GROUP><ID>104</ID><..."
Fri Oct 23 09:00:52 2026 [Z0][AuM][D]: _authenticate: -
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:3040 UID:1 IP:127.0.0.1 one.system.config invoked
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:3040 UID:1 one.system.config result SUCCESS, "<OPENNEBULA_CONFIGUR..."
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:8912 UID:234 IP:127.0.0.1 one.grouppool.info invoked
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: Reverse search request #234 GROUP/* USE #0
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: > Rule @104 NET/* USE #0
Fri Oct 23 09:00:52 2026 [Z0][ACL][DD]: > Rule @104 DATASTORE/* USE #0
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:8912 UID:234 one.grouppool.info result SUCCESS, "<GROUP_POOL><GROUP><..."
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:7648 UID:234 IP:127.0.0.1 one.system.version invoked
Fri Oct 23 09:00:52 2026 [Z0][ReM][D]: Req:7648 UID:234 one.system.version result SUCCESS, "7.0.1"
Fri Oct 23 09:00:53 2026 [Z0][ReM][DD]: Number of active connections: 1
Fri Oct 23 09:00:53 2026 [Z0][AuM][D]: _authenticate: -
Fri Oct 23 09:00:53 2026 [Z0][ReM][D]: Req:8480 UID:1 IP:127.0.0.1 one.user.info invoked , 234, true
Fri Oct 23 09:00:53 2026 [Z0][ReM][D]: Req:8480 UID:1 one.user.info result SUCCESS, "<USER><ID>234</ID><G..."
Fri Oct 23 09:00:53 2026 [Z0][ReM][D]: Req:1120 UID:1 IP:127.0.0.1 one.vm.info invoked , 8931, true
Fri Oct 23 09:00:53 2026 [Z0][ReM][D]: Req:1120 UID:1 one.vm.info result SUCCESS, "<VM><ID>8931</ID><UI..."
Fri Oct 23 09:00:53 2026 [Z0][ReM][D]: Req:592 UID:234 IP:127.0.0.1 one.vm.info invoked , 8931, false
Fri Oct 23 09:00:53 2026 [Z0][ACL][DD]: Request #234 VM/#8931 USE #0
Fri Oct 23 09:00:53 2026 [Z0][ACL][DD]: > Rule * VM/#8931 #0
Fri Oct 23 09:00:53 2026 [Z0][ACL][DD]: > Rule * ZONE/* USE *
Fri Oct 23 09:00:53 2026 [Z0][ACL][DD]: > Rule * MARKETPLACE+MARKETPLACEAPP/* USE *
Fri Oct 23 09:00:53 2026 [Z0][ACL][DD]: > Rule @104 HOST/* MANAGE #0
Fri Oct 23 09:00:53 2026 [Z0][ACL][DD]: > Rule @104 NET/* USE #0
Fri Oct 23 09:00:53 2026 [Z0][ACL][DD]: > Rule @104 DATASTORE/* USE #0
Fri Oct 23 09:00:53 2026 [Z0][ACL][DD]: > Rule @104 VM+TEMPLATE/* CREATE *
Fri Oct 23 09:00:53 2026 [Z0][ACL][DD]: No more rules, permission not granted
Fri Oct 23 09:00:53 2026 [Z0][ReM][E]: Req:592 UID:234 one.vm.info result FAILURE [one.vm.info] User [234] : Not authorized to perform USE VM [8931].
Last two lines:
- Fri Oct 23 09:00:53 2026 [Z0][ACL][DD]: No more rules, permission not granted
- Fri Oct 23 09:00:53 2026 [Z0][ReM][E]: Req:592 UID:234 one.vm.info result FAILURE [one.vm.info] User [234] : Not authorized to perform USE VM [8931].
But, again, permission is granted as you can see at browser tab:
In both cases, browers shows “Connection established” in green colour and “not authorized to perform use vm” in red colour and, also, date and time is “#undefined” (top left corner)
I attach all my ACL list (it’s a long list because there are many groups with many users and in each group there are more than one “admin”). Users and groups affected in this post are:
- users: 103 and 234
- groups: 102 and 104
It’s a big problem for me what is happening… If somebody could help me, I would be eternally grateful for it.
Thanks in advance.
