# VMs with cpu=host-passthrough can not migrate b/w same cpu hosts
**URL:** <https://forum.opennebula.io/t/vms-with-cpu-host-passthrough-can-not-migrate-b-w-same-cpu-hosts/7232>\
**Category:** Installation & Configuration\
**Created:** [May 16, 2019, 9:31am UTC](https://forum.opennebula.io/t/vms-with-cpu-host-passthrough-can-not-migrate-b-w-same-cpu-hosts/7232 "2019-05-16T09:31:44Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![Hoang\_Hien\_Nguyen](https://yyz1.discourse-cdn.com/flex031/user_avatar/forum.opennebula.io/hoang_hien_nguyen/32/6221_2.png) [@Hoang\_Hien\_Nguyen](https://forum.opennebula.io/u/Hoang_Hien_Nguyen)\
**Post date:** [May 16, 2019, 9:31am UTC](https://forum.opennebula.io/t/vms-with-cpu-host-passthrough-can-not-migrate-b-w-same-cpu-hosts/7232/1 "2019-05-16T09:31:44Z")
</div>
I am using opennebula 5.6.0. Any VMs with cpu=host-passthrough can not migrate between hosts with exact same CPU.
Here is the error log:
Thu May 16 16:02:45 2019 [Z0][VMM][E]: restore: Command “virsh --connect qemu:///system restore /var/lib/one//datastores/0/652/checkpoint --xml /var/lib/one//datastores/0/652/checkpoint.xml” failed: error: Failed to restore domain from /var/lib/one//datastores/0/652/checkpoint
Thu May 16 16:02:45 2019 [Z0][VMM][I]: error: **unsupported configuration: Target CPU model [null] does not match source Broadwell-IBRS**
Thu May 16 16:02:45 2019 [Z0][VMM][E]: Could not restore from /var/lib/one//datastores/0/652/checkpoint
