In my environment I have set the GRAPHICS parameter as it is explained in the documentation:
https://docs.opennebula.org/5.2/operation/references/template.html#xml-syntax
TYPE: values: vnc, sdl, spice
LISTEN: IP to listen on.
PORT: port for the VNC server
PASSWD: password for the VNC server
KEYMAP: keyboard configuration locale to use in the VNC display
RANDOM_PASSWD: if “YES”, generate a random password for each VM
In my example:
GRAPHICS = [
KEYMAP = “es”,
LISTEN = “0.0.0.0”,
TYPE = “SPICE” ]
I’d like to customize my graphics tag in Deployment.X (xml) to make it look like:
<graphics type='spice' port='5922' autoport='no' listen='0.0.0.0' keymap='es'> <listen type='address' address='0.0.0.0'/> <image compression='auto_glz'/> <streaming mode='filter'/> </graphics>
It is, add the following tags.
I have tried to add the whole in the available RAW parameter, but system raises an error because it is not possible to have 2 spice video devices.
If I delete the GRAPHICS parameter, I can set my custom tag in the RAW parameter, but by this way I have to set “autoport=yes” or assign the spice port manually.
In this scenario,
Is there any way to add raw data to the GRAPHICS template parameter?
If I set the autoport=yes, is there any way to know which port has been assigned to the guest VM?
Is it always the same port, or everytime I power-on the guest the system will assign a new one?
Thanks a lot.
