We are having some issues using VXLAN networks, it sometimes seems to have issues sending arp request across the bridge it creates meaning machines within the network cannot talk to each other.
We have a number of KVM nodes which are connected to a single switch via an interface called privlan, after creating a vxlan network it seems to create the bridge and attach the interfaces as expected.
VIRTUAL NETWORK 482 INFORMATION
USER : m12233
GROUP : oneadmin
LOCK : None
CLUSTERS : 0
BRIDGE : onebr482
VN_MAD : vxlan
PHYSICAL DEVICE : privlan
VLAN ID : 484
AUTOMATIC VLAN ID : YES
AUTOMATIC OUTER VLAN ID : NO
USED LEASES : 4
OWNER : um-
GROUP : ---
OTHER : ---
VIRTUAL NETWORK TEMPLATE
BRIDGE="onebr482"
BRIDGE_TYPE="linux"
CLUSTERS="0"
DESCRIPTION="Template for creating a Private network using VXLAN"
OUTER_VLAN_ID=""
PHYDEV="privlan"
SECURITY_GROUPS="0"
TEMPLATE_ID="0"
VN_MAD="vxlan"
ADDRESS RANGE POOL
AR 0
LEASES : 4
RANGE FIRST LAST
MAC 02:00:c0:a8:00:01 02:00:c0:a8:ff:fd
IP 192.168.0.1 192.168.255.253
LEASES
AR OWNER MAC IP IP6
0 V:2422 02:00:c0:a8:00:01 192.168.0.1 -
0 V:2423 02:00:c0:a8:00:02 192.168.0.2 -
0 V:2424 02:00:c0:a8:00:03 192.168.0.3 -
0 V:2425 02:00:c0:a8:00:04 192.168.0.4 -
brctl:
onebr482 8000.ce1591a77b71 no one-2422-0
privlan.484
but pinging from one vm to another it fails, tcpdumping the bridge interface we can see it sending out arp requests, but it doesn’t seem to get responses and tcpdumping the same bridge on the other kvm node where the other vm is running is seeing no arp requests:
00:50:47.465925 ARP, Request who-has 192.168.0.2 tell 192.168.0.3, length 28
