What version of ONE you using? I believe the latest version will change the VM state to running if it finds the VM still running on the host. So, you can use the “POWEROFF” state to create VM hook to start the VM again.
On the other hand, you can use host hook (failure) and re-deploy the VM in other host. But you need to careful with this as sometime the VM still running on that host but the frontend is unable to connect to host for monitoring.
I killed the KVM process of a testing VM, here is the log:
Tue Oct 4 08:57:37 2016 [Z0][LCM][I]: VM running but monitor state is POWEROFF
Tue Oct 4 08:57:37 2016 [Z0][VM][I]: New LCM state is SHUTDOWN_POWEROFF
Tue Oct 4 08:57:37 2016 [Z0][VM][I]: New state is POWEROFF
Tue Oct 4 08:57:37 2016 [Z0][VM][I]: New LCM state is LCM_INIT
According to this log, I could not use a HOOK on POWEROFF since I
can’t make distinction between a user running onevm poweroff and the
actions run automatically with the monitoring.
We are using fencing since we have corosync/pacemaker/cLVM/GFS2, but
some time to time the whole stack get crasy on all hypervisors and they
are all rebooted :-/
I would like to manage the single node case too.
Daniel Dehennin
