Hello everyone after creating my microvm firecracker i want to access using vnc but it’s tell me CLIENT_ERROR i’m using vmware workstation why ??
Can you clarify your setup ? Are you using FireCracker + VMWare as hypervisors ?
i’m using VMWare workstation to create my test virtual environment and firecracker as hypervisor .
Does this happen only with FireCracker VMs ? Make sure you have FireEdge properly configured
FireEdge is configured properly yes
i reslove the problem all things work fine , i forget to turn ON KVM acceleration can be used and also /dev/kvm permission in firecracker node
