I am using version 5.4.6 with following manual
https://docs.opennebula.org/5.4/advanced_components/cloud_bursting/azg.html
for connecting to Azure.
Some question:
- Under Prerequisites section of manual
Those ssl key is generated under the OpenNebula node?
- After step of create host by “onehost create west-europe -i az -v az”. I find there is ERROR showing from Sunstone
Wed Feb 7 16:54:38 2018 : Error monitoring Host east-asia (3): Error executing poll
and from /var/log/one/oned.log. It have repeating error log
Wed Feb 7 16:54:08 2018 [Z0][ONE][E]: Error monitoring Host east-asia (2): Error executing poll
Wed Feb 7 16:54:17 2018 [Z0][InM][I]: Command execution fail: 'if [ -x “/var/tmp/one/im/stop_probes” ]; then /var/tmp/one/im/stop_probes az 2 east-asia; else exit 42; fi’
Wed Feb 7 16:54:17 2018 [Z0][InM][I]: ssh: Could not resolve hostname east-asia: Name or service not known
Wed Feb 7 16:54:30 2018 [Z0][ReM][D]: Req:6384 UID:0 one.host.allocate invoked , “east-asia”, “az”, “az”, 0
Wed Feb 7 16:54:36 2018 [Z0][InM][D]: Monitoring host east-asia (3)
Wed Feb 7 16:54:38 2018 [Z0][InM][I]: Command execution fail: /var/lib/one/remotes/im/run_probes az /var/lib/one//datastores 4124 20 3 east-asia
Wed Feb 7 16:54:38 2018 [Z0][ONE][E]: Error monitoring Host east-asia (3): Error executing poll
[root@opennebula azure]#
Could you please advise how to trace and fix the problem?
Thanks!
