a fresh install of ONe 5.10.1 on a Debian 10 node behaves quite different than I’m used to with Ubuntu 16.04/18.04. It starts with “virsh list” being empty when run from the oneadmin user; under Ubuntu, this just gives the list of VMs. Starting a VM on Debian 10 yields in “Boot failed: not a bootable disk”.
Versions of the related components and OS (frontend, hypervisors, VMs): Frontend: opennebula 5.10.1-1 on Debian 10u2-VM created with virt-manager running on host “vmhost04”; Hypervisor: “vmhost04” running Debian 10u2, opennebula-node 5.10.1-1.
Steps to reproduce: Take fresh Debian 10u2 Host, install opennebula-node as per Documentation, try “su - oneadmin -c ‘virsh list’”. Furthermore, try to boot a VM via ONe Frontend on this host; doesn’t work here, BIOS says no boot disk, ONe Frontend says “runn”.
root@vmhost04 ~ # echo "As oneadmin user:" ; su - oneadmin -c "virsh list" ; echo ; echo "Meanwhile as root:" ; echo ; virsh list ; uname -a
As oneadmin user:
Id Name State
Meanwhile as root:
Id Name State
1 one-a running
2 one-1 running
Linux vmhost04 4.19.0-6-amd64 #1 SMP Debian 4.19.67-2+deb10u2 (2019-11-11) x86_64 GNU/Linux
root@ubuntu1604:~# echo "As oneadmin user:" ; su - oneadmin -c "virsh list" ; echo ; echo "Meanwhile as root:" ; echo ; virsh list ; uname -a
As oneadmin user:
Id Name State
2 one-203 running
3 one-250 running
5 one-236 running
6 one-117 running
7 one-266 running
8 one-221 running
10 one-275 running
12 one-285 running
13 one-245 running
Meanwhile as root:
Id Name State
2 one-203 running
3 one-250 running
5 one-236 running
6 one-117 running
7 one-266 running
8 one-221 running
10 one-275 running
12 one-285 running
13 one-245 running
Linux ubuntu1604 4.15.0-66-generic #75~16.04.1-Ubuntu SMP Tue Oct 1 14:01:08 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
