Clean setup with VOneCloud 6.6.0 & vCenter 8
Deploying the first VM results fail, see the logs below:
Logs tab on sunstone:
Wed Mar 22 18:21:19 2023 [Z0][VM][I]: New state is ACTIVE
Wed Mar 22 18:21:19 2023 [Z0][VM][I]: New LCM state is PROLOG
Wed Mar 22 18:21:33 2023 [Z0][VM][I]: New LCM state is BOOT
Wed Mar 22 18:21:33 2023 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/0/deployment.0
Wed Mar 22 18:21:33 2023 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Wed Mar 22 18:21:33 2023 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Wed Mar 22 18:21:33 2023 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/mkdir -p.
Wed Mar 22 18:21:33 2023 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one/vms/0/vm.xml.
Wed Mar 22 18:21:33 2023 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one/vms/0/ds.xml.
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: Command execution failed (exit code: 255): /var/lib/one/remotes/vmm/vcenter/deploy '/var/lib/one/vms/0/deployment.0' 'OpenCluster01' 0 OpenCluster01
Wed Mar 22 18:21:48 2023 [Z0][VMM][E]: deploy: Deploy of VM 0 on vCenter cluster OpenCluster01 with /var/lib/one/vms/0/deployment.0 failed due to "InvalidRequest:
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: Cannot parse "3222138429" as an int value
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing serialized value of type int
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 931
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing property "key" of static type int
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing serialized DataObject of type vim.vm.device.VirtualVmxnet3
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 897
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing property "device" of static type VirtualDevice
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing serialized DataObject of type vim.vm.device.VirtualDeviceSpec
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 822
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing property "deviceChange" of static type ArrayOfVirtualDeviceConfigSpec
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing serialized DataObject of type vim.vm.ConfigSpec
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 256
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing call information for method ReconfigVM_Task
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 177
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing SOAP body
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 167
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing SOAP envelope
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 0
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: while parsing HTTP request for method reconfigure
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: on object of type vim.VirtualMachine
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 0"on attempt #0.
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: Deploy of VM 0 on vCenter cluster OpenCluster01 with /var/lib/one/vms/0/deployment.0 failed due to "InvalidRequest:
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 0"on attempt #0. ["/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:63:in `parse_response'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:92:in `call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:213:in `_call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:76:in `block (2 levels) in init'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:1798:in `sync'", "/var/lib/one/remotes/vmm/vcenter/deploy:135:in `<main>'"]
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: Cannot parse "3222142120" as an int value
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 0"on attempt #1.
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 0"on attempt #1. ["/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:63:in `parse_response'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:92:in `call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:213:in `_call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:76:in `block (2 levels) in init'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:1798:in `sync'", "/var/lib/one/remotes/vmm/vcenter/deploy:135:in `<main>'"]
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: Cannot parse "3222146933" as an int value
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 0"on attempt #2.
Wed Mar 22 18:21:48 2023 [Z0][VMM][I]: at line 1, column 0"on attempt #2. ["/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:63:in `parse_response'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:92:in `call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:213:in `_call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:76:in `block (2 levels) in init'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:1798:in `sync'", "/var/lib/one/remotes/vmm/vcenter/deploy:135:in `<main>'"]
Wed Mar 22 18:21:53 2023 [Z0][VMM][I]: Successfully execute network driver operation: clean.
Wed Mar 22 18:21:53 2023 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Wed Mar 22 18:21:53 2023 [Z0][VMM][E]: DEPLOY: ERROR: deploy: Deploy of VM 0 on vCenter cluster OpenCluster01 with /var/lib/one/vms/0/deployment.0 failed due to "InvalidRequest: Cannot parse "3222138429" as an int value while parsing serialized value of type int at line 1, column 931 while parsing property "key" of static type int while parsing serialized DataObject of type vim.vm.device.VirtualVmxnet3 at line 1, column 897 while parsing property "device" of static type VirtualDevice while parsing serialized DataObject of type vim.vm.device.VirtualDeviceSpec at line 1, column 822 while parsing property "deviceChange" of static type ArrayOfVirtualDeviceConfigSpec while parsing serialized DataObject of type vim.vm.ConfigSpec at line 1, column 256 while parsing call information for method ReconfigVM_Task at line 1, column 177 while parsing SOAP body at line 1, column 167 while parsing SOAP envelope at line 1, column 0 while parsing HTTP request for method reconfigure on object of type vim.VirtualMachine at line 1, column 0"on attempt #0. Deploy of VM 0 on vCenter cluster OpenCluster01 with /var/lib/one/vms/0/deployment.0 failed due to "InvalidRequest: Cannot parse "3222138429" as an int value while parsing serialized value of type int at line 1, column 931 while parsing property "key" of static type int while parsing serialized DataObject of type vim.vm.device.VirtualVmxnet3 at line 1, column 897 while parsing property "device" of static type VirtualDevice while parsing serialized DataObject of type vim.vm.device.VirtualDeviceSpec at line 1, column 822 while parsing property "deviceChange" of static type ArrayOfVirtualDeviceConfigSpec while parsing serialized DataObject of type vim.vm.ConfigSpec at line 1, column 256 while parsing call information for method ReconfigVM_Task at line 1, column 177 while parsing SOAP body at line 1, column 167 while parsing SOAP envelope at line 1, column 0 while parsing HTTP request for method reconfigure on object of type vim.VirtualMachine at line 1, column 0"on attempt #0. ["/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:63:in `parse_response'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:92:in `call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:213:in `_call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:76:in `block (2 levels) in init'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:1798:in `sync'", "/var/lib/one/remotes/vmm/vcenter/deploy:135:in `<main>'"] ERROR: deploy: Deploy of VM 0 on vCenter cluster OpenCluster01 with /var/lib/one/vms/0/deployment.0 failed due to "InvalidRequest: Cannot parse "3222142120" as an int value while parsing serialized value of type int at line 1, column 931 while parsing property "key" of static type int while parsing serialized DataObject of type vim.vm.device.VirtualVmxnet3 at line 1, column 897 while parsing property "device" of static type VirtualDevice while parsing serialized DataObject of type vim.vm.device.VirtualDeviceSpec at line 1, column 822 while parsing property "deviceChange" of static type ArrayOfVirtualDeviceConfigSpec while parsing serialized DataObject of type vim.vm.ConfigSpec at line 1, column 256 while parsing call information for method ReconfigVM_Task at line 1, column 177 while parsing SOAP body at line 1, column 167 while parsing SOAP envelope at line 1, column 0 while parsing HTTP request for method reconfigure on object of type vim.VirtualMachine at line 1, column 0"on attempt #1. Deploy of VM 0 on vCenter cluster OpenCluster01 with /var/lib/one/vms/0/deployment.0 failed due to "InvalidRequest: Cannot parse "3222142120" as an int value while parsing serialized value of type int at line 1, column 931 while parsing property "key" of static type int while parsing serialized DataObject of type vim.vm.device.VirtualVmxnet3 at line 1, column 897 while parsing property "device" of static type VirtualDevice while parsing serialized DataObject of type vim.vm.device.VirtualDeviceSpec at line 1, column 822 while parsing property "deviceChange" of static type ArrayOfVirtualDeviceConfigSpec while parsing serialized DataObject of type vim.vm.ConfigSpec at line 1, column 256 while parsing call information for method ReconfigVM_Task at line 1, column 177 while parsing SOAP body at line 1, column 167 while parsing SOAP envelope at line 1, column 0 while parsing HTTP request for method reconfigure on object of type vim.VirtualMachine at line 1, column 0"on attempt #1. ["/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:63:in `parse_response'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:92:in `call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:213:in `_call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:76:in `block (2 levels) in init'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:1798:in `sync'", "/var/lib/one/remotes/vmm/vcenter/deploy:135:in `<main>'"] ERROR: deploy: Deploy of VM 0 on vCenter cluster OpenCluster01 with /var/lib/one/vms/0/deployment.0 failed due to "InvalidRequest: Cannot parse "3222146933" as an int value while parsing serialized value of type int at line 1, column 931 while parsing property "key" of static type int while parsing serialized DataObject of type vim.vm.device.VirtualVmxnet3 at line 1, column 897 while parsing property "device" of static type VirtualDevice while parsing serialized DataObject of type vim.vm.device.VirtualDeviceSpec at line 1, column 822 while parsing property "deviceChange" of static type ArrayOfVirtualDeviceConfigSpec while parsing serialized DataObject of type vim.vm.ConfigSpec at line 1, column 256 while parsing call information for method ReconfigVM_Task at line 1, column 177 while parsing SOAP body at line 1, column 167 while parsing SOAP envelope at line 1, column 0 while parsing HTTP request for method reconfigure on object of type vim.VirtualMachine at line 1, column 0"on attempt #2. Deploy of VM 0 on vCenter cluster OpenCluster01 with /var/lib/one/vms/0/deployment.0 failed due to "InvalidRequest: Cannot parse "3222146933" as an int value while parsing serialized value of type int at line 1, column 931 while parsing property "key" of static type int while parsing serialized DataObject of type vim.vm.device.VirtualVmxnet3 at line 1, column 897 while parsing property "device" of static type VirtualDevice while parsing serialized DataObject of type vim.vm.device.VirtualDeviceSpec at line 1, column 822 while parsing property "deviceChange" of static type ArrayOfVirtualDeviceConfigSpec while parsing serialized DataObject of type vim.vm.ConfigSpec at line 1, column 256 while parsing call information for method ReconfigVM_Task at line 1, column 177 while parsing SOAP body at line 1, column 167 while parsing SOAP envelope at line 1, column 0 while parsing HTTP request for method reconfigure on object of type vim.VirtualMachine at line 1, column 0"on attempt #2. ["/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:63:in `parse_response'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/connection.rb:92:in `call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:213:in `_call'", "/usr/share/one/gems-dist/gems/rbvmomi-3.0.0/lib/rbvmomi/basic_types.rb:76:in `block (2 levels) in init'", "/usr/lib/one/ruby/vcenter_driver/virtual_machine.rb:1798:in `sync'", "/var/lib/one/remotes/vmm/vcenter/deploy:135:in `<main>'"]
Wed Mar 22 18:21:53 2023 [Z0][VM][I]: New LCM state is BOOT_FAILURE
<VM><ID>0</ID><UID>0</UID><GID>0</GID><UNAME>oneadmin</UNAME><GNAME>oneadmin</GNAME><NAME>test-1</NAME><PERMISSIONS><OWNER_U>1</OWNER_U><OWNER_M>1</OWNER_M><OWNER_A>0</OWNER_A><GROUP_U>0</GROUP_U><GROUP_M>0</GROUP_M><GROUP_A>0</GROUP_A><OTHER_U>0</OTHER_U><OTHER_M>0</OTHER_M><OTHER_A>0</OTHER_A></PERMISSIONS><LAST_POLL>0</LAST_POLL><STATE>3</STATE><LCM_STATE>2</LCM_STATE><PREV_STATE>3</PREV_STATE><PREV_LCM_STATE>2</PREV_LCM_STATE><RESCHED>0</RESCHED><STIME>1679509278</STIME><ETIME>0</ETIME><DEPLOY_ID></DEPLOY_ID><MONITORING></MONITORING><TEMPLATE><AUTOMATIC_DS_REQUIREMENTS><![CDATA[("CLUSTERS/ID" @> 103)]]></AUTOMATIC_DS_REQUIREMENTS><AUTOMATIC_NIC_REQUIREMENTS><![CDATA[("CLUSTERS/ID" @> 103)]]></AUTOMATIC_NIC_REQUIREMENTS><AUTOMATIC_REQUIREMENTS><![CDATA[(CLUSTER_ID = 103) & !(PUBLIC_CLOUD = YES) & !(PIN_POLICY = PINNED)]]></AUTOMATIC_REQUIREMENTS><CONTEXT><DISK_ID><![CDATA[1]]></DISK_ID><ETH0_DNS><![CDATA[]]></ETH0_DNS><ETH0_EXTERNAL><![CDATA[]]></ETH0_EXTERNAL><ETH0_GATEWAY><![CDATA[]]></ETH0_GATEWAY><ETH0_IP><![CDATA[45.11.97.195]]></ETH0_IP><ETH0_IP6><![CDATA[]]></ETH0_IP6><ETH0_IP6_GATEWAY><![CDATA[]]></ETH0_IP6_GATEWAY><ETH0_IP6_METHOD><![CDATA[]]></ETH0_IP6_METHOD><ETH0_IP6_METRIC><![CDATA[]]></ETH0_IP6_METRIC><ETH0_IP6_PREFIX_LENGTH><![CDATA[]]></ETH0_IP6_PREFIX_LENGTH><ETH0_IP6_ULA><![CDATA[]]></ETH0_IP6_ULA><ETH0_MAC><![CDATA[02:00:bf:fa:49:b1]]></ETH0_MAC><ETH0_MASK><![CDATA[]]></ETH0_MASK><ETH0_METHOD><![CDATA[]]></ETH0_METHOD><ETH0_METRIC><![CDATA[]]></ETH0_METRIC><ETH0_MTU><![CDATA[]]></ETH0_MTU><ETH0_NETWORK><![CDATA[]]></ETH0_NETWORK><ETH0_SEARCH_DOMAIN><![CDATA[]]></ETH0_SEARCH_DOMAIN><ETH0_VLAN_ID><![CDATA[]]></ETH0_VLAN_ID><ETH0_VROUTER_IP><![CDATA[]]></ETH0_VROUTER_IP><ETH0_VROUTER_IP6><![CDATA[]]></ETH0_VROUTER_IP6><ETH0_VROUTER_MANAGEMENT><![CDATA[]]></ETH0_VROUTER_MANAGEMENT><NETWORK><![CDATA[YES]]></NETWORK><SSH_PUBLIC_KEY><![CDATA[ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDELTcqXueng2MkpVDr6x20x8w8ZnkVXV7Skee4NpKvr/+Ri7G6JwOL57s4SX7yr47FOLP5IU/m0X/Fxx451k9tay/SDNPWDOy6mGCQkfKkYLqAkq3nJrP7I6r8ifxpDNgarhrsTXq+4ZvzeEjtIAOuYZ5Kc6cYYCcgJwltdRJ9Dh4Ipl6hKGpEm9Dl7rdCj3bk8SkCD6ptPIgWh5+gR/yAMfsA8a5qxItPKe2FhS0f3nOnbOPyAfStR/lmY0VKylCxvktogw5OWkhtCU0wqqqTJr1VdGHqATGBqHE/czdO8hRJdkEOTaOOC3ZLz8c0AdoTnTNhIoPBcwDbOp9mbYyf Mehmet@Mehmets-MacBook]]></SSH_PUBLIC_KEY><TARGET><![CDATA[hda]]></TARGET></CONTEXT><CPU><![CDATA[1]]></CPU><DISK><ALLOW_ORPHANS><![CDATA[NO]]></ALLOW_ORPHANS><CLONE><![CDATA[YES]]></CLONE><CLONE_TARGET><![CDATA[SYSTEM]]></CLONE_TARGET><CLUSTER_ID><![CDATA[103]]></CLUSTER_ID><DATASTORE><![CDATA[SAS_RAID700 (1)(IMG)]]></DATASTORE><DATASTORE_ID><![CDATA[100]]></DATASTORE_ID><DEV_PREFIX><![CDATA[sd]]></DEV_PREFIX><DISK_ID><![CDATA[0]]></DISK_ID><DISK_SNAPSHOT_TOTAL_SIZE><![CDATA[0]]></DISK_SNAPSHOT_TOTAL_SIZE><DISK_TYPE><![CDATA[FILE]]></DISK_TYPE><DRIVER><![CDATA[vmdk]]></DRIVER><FORMAT><![CDATA[vmdk]]></FORMAT><IMAGE><![CDATA[Ubuntu 22.04]]></IMAGE><IMAGE_ID><![CDATA[1]]></IMAGE_ID><IMAGE_STATE><![CDATA[2]]></IMAGE_STATE><LN_TARGET><![CDATA[NONE]]></LN_TARGET><ORIGINAL_SIZE><![CDATA[2252]]></ORIGINAL_SIZE><READONLY><![CDATA[NO]]></READONLY><SAVE><![CDATA[NO]]></SAVE><SIZE><![CDATA[5120]]></SIZE><SOURCE><![CDATA[one/1/0.vmdk]]></SOURCE><TARGET><![CDATA[sda]]></TARGET><TM_MAD><![CDATA[vcenter]]></TM_MAD><TYPE><![CDATA[FILE]]></TYPE><VCENTER_DS_REF><![CDATA[datastore-3004]]></VCENTER_DS_REF><VCENTER_INSTANCE_ID><![CDATA[751a61e3-3555-4c1e-be1d-50314a61eac7]]></VCENTER_INSTANCE_ID></DISK><GRAPHICS><LISTEN><![CDATA[0.0.0.0]]></LISTEN><PORT><![CDATA[5900]]></PORT><TYPE><![CDATA[vnc]]></TYPE></GRAPHICS><MEMORY><![CDATA[1024]]></MEMORY><NIC><AR_ID><![CDATA[0]]></AR_ID><BRIDGE><![CDATA[Internet]]></BRIDGE><BRIDGE_TYPE><![CDATA[vcenter_port_groups]]></BRIDGE_TYPE><CLUSTER_ID><![CDATA[103]]></CLUSTER_ID><IP><![CDATA[45.11.97.195]]></IP><MAC><![CDATA[02:00:bf:fa:49:b1]]></MAC><NAME><![CDATA[NIC0]]></NAME><NETWORK><![CDATA[Internet]]></NETWORK><NETWORK_ID><![CDATA[0]]></NETWORK_ID><NIC_ID><![CDATA[0]]></NIC_ID><SECURITY_GROUPS><![CDATA[0]]></SECURITY_GROUPS><TARGET><![CDATA[one-0-0]]></TARGET><VCENTER_INSTANCE_ID><![CDATA[751a61e3-3555-4c1e-be1d-50314a61eac7]]></VCENTER_INSTANCE_ID><VCENTER_NET_REF><![CDATA[dvportgroup-2061]]></VCENTER_NET_REF><VCENTER_PORTGROUP_TYPE><![CDATA[Distributed Port Group]]></VCENTER_PORTGROUP_TYPE><VCENTER_SWITCH_NAME><![CDATA[Public]]></VCENTER_SWITCH_NAME><VN_MAD><![CDATA[vcenter]]></VN_MAD></NIC><OS><ARCH><![CDATA[x86_64]]></ARCH><UUID><![CDATA[3a4344da-5268-4693-877a-37cf5b5d1682]]></UUID></OS><SECURITY_GROUP_RULE><PROTOCOL><![CDATA[ALL]]></PROTOCOL><RULE_TYPE><![CDATA[OUTBOUND]]></RULE_TYPE><SECURITY_GROUP_ID><![CDATA[0]]></SECURITY_GROUP_ID><SECURITY_GROUP_NAME><![CDATA[default]]></SECURITY_GROUP_NAME></SECURITY_GROUP_RULE><SECURITY_GROUP_RULE><PROTOCOL><![CDATA[ALL]]></PROTOCOL><RULE_TYPE><![CDATA[INBOUND]]></RULE_TYPE><SECURITY_GROUP_ID><![CDATA[0]]></SECURITY_GROUP_ID><SECURITY_GROUP_NAME><![CDATA[default]]></SECURITY_GROUP_NAME></SECURITY_GROUP_RULE><TEMPLATE_ID><![CDATA[0]]></TEMPLATE_ID><TM_MAD_SYSTEM><![CDATA[vcenter]]></TM_MAD_SYSTEM><VMID><![CDATA[0]]></VMID></TEMPLATE><USER_TEMPLATE><HYPERVISOR><![CDATA[vcenter]]></HYPERVISOR><LOGO><![CDATA[images/logos/ubuntu.png]]></LOGO><LXD_SECURITY_PRIVILEGED><![CDATA[true]]></LXD_SECURITY_PRIVILEGED><VCENTER_CCR_REF><![CDATA[domain-c3035]]></VCENTER_CCR_REF><VCENTER_INSTANCE_ID><![CDATA[751a61e3-3555-4c1e-be1d-50314a61eac7]]></VCENTER_INSTANCE_ID><VCENTER_TEMPLATE_REF><![CDATA[vm-4619]]></VCENTER_TEMPLATE_REF></USER_TEMPLATE><HISTORY_RECORDS><HISTORY><OID>0</OID><SEQ>0</SEQ><HOSTNAME>OpenCluster01</HOSTNAME><HID>4</HID><CID>103</CID><STIME>1679509279</STIME><ETIME>0</ETIME><VM_MAD><![CDATA[vcenter]]></VM_MAD><TM_MAD><![CDATA[vcenter]]></TM_MAD><DS_ID>103</DS_ID><PSTIME>1679509279</PSTIME><PETIME>1679509293</PETIME><RSTIME>1679509293</RSTIME><RETIME>0</RETIME><ESTIME>0</ESTIME><EETIME>0</EETIME><ACTION>0</ACTION><UID>-1</UID><GID>-1</GID><REQUEST_ID>-1</REQUEST_ID></HISTORY></HISTORY_RECORDS><BACKUPS><BACKUP_CONFIG/><BACKUP_IDS></BACKUP_IDS></BACKUPS></VM>
Vcenter Task Logs
