Hello
I’m having this same issue
with the difference that I’m using 8021Q Network Driver, LXC and OpenNebula 4.14.2. Is there any workaround in this case?
This is the log
Wed Jan 20 12:04:09 2016 [Z0][VM][I]: New state is ACTIVE
Wed Jan 20 12:04:10 2016 [Z0][VM][I]: New LCM state is PROLOG
Wed Jan 20 12:04:11 2016 [Z0][VM][I]: New LCM state is BOOT
Wed Jan 20 12:04:11 2016 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/4/deployment.0
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: Command execution fail: /var/tmp/one/vnm/802.1Q/pre 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
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: /var/tmp/one/vnm/nic.rb:36:in new_nic': undefined methodnew’ for nil:NilClass (NoMethodError)
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /var/tmp/one/vnm/vm.rb:46:in block in initialize' Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /usr/lib/ruby/2.1.0/rexml/element.rb:902:inblock in each’
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /usr/lib/ruby/2.1.0/rexml/xpath.rb:67:in each' Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /usr/lib/ruby/2.1.0/rexml/xpath.rb:67:ineach’
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /usr/lib/ruby/2.1.0/rexml/element.rb:902:in each' Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /var/tmp/one/vnm/vm.rb:45:ininitialize’
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /var/tmp/one/vnm/vnm_driver.rb:46:in new' Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /var/tmp/one/vnm/vnm_driver.rb:46:ininitialize’
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /var/tmp/one/vnm/vlan.rb:29:in initialize' Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /var/tmp/one/vnm/802.1Q/vlan_tag_driver.rb:38:ininitialize’
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /var/tmp/one/vnm/vnm_driver.rb:56:in new' Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /var/tmp/one/vnm/vnm_driver.rb:56:infrom_base64’
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: from /var/tmp/one/vnm/802.1Q/pre:24:in `'
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: ExitCode: 1
Wed Jan 20 12:04:12 2016 [Z0][VMM][I]: Failed to execute network driver operation: pre.
Wed Jan 20 12:04:12 2016 [Z0][VMM][E]: Error deploying virtual machine
Wed Jan 20 12:04:12 2016 [Z0][VM][I]: New LCM state is BOOT_FAILURE
Thanks
