Deplying machine error: ManagedObjectNotFound
Message received: DEPLOY FAILURE 1169 ERROR: deploy: Deploy of VM 1169 on vCrs with /home/oneadmin/nebula/var/vms/1169/deployment.0 failed due to "ManagedObjectNotFound: The object has alreadbeen completely created"on attempt #0. ERROR: deploy: Deploy of VM 1169 on vCenter cluster CC with /hom1169/deployment.0 failed due to "ManagedObjectNotFound: The object has already been deleted or has not been complet ERROR: deploy: Deploy of VM 1169 on vCenter cluster CC with /home/oneadmin/nebula/var/vms/1169/deploymedObjectNotFound: The object has already been deleted or has not been completely created"on attempt #2.
The image gets copied and vmdk is there. What would you suggest can I do to troubleshoot this ?
