Hello All,
I am new here and installed my first Open Nebule. I have followed this guide for installation:
http://docs.opennebula.org/4.12/design_and_installation/quick_starts/qs_centos7_kvm.html
The installation went fine but when it comes to bridging eth0 to br0 nothing seems to work.
Here is my bridging configuration:
eth0
DEVICE=eth0
TYPE=Ethernet
HWADDR=C8:60:00:56:B1:FD
BOOTPROTO=none
ONBOOT=yes
NM_CONTROLLED=no
BRIDGE=br0
br0
DEVICE=br0
TYPE=Bridge
IPADDR=176.9.151.101
NETMASK=255.255.255.255
SCOPE=“peer 176.9.151.97”
ONBOOT=yes
BOOTPROTO=static
NM_CONTROLLED=no
DELAY=0
When I run service network restart I am getting following error:
device br0#015 does not seem to be present, delaying initialization
eth0 or br0 does not get the IP address.
For workaround I have run and added /etc/rc.d/rc.local
ifconfig eth0 176.9.151.101 netmask 255.255.255.224 broatcast 176.9.151.127
sleep 1
ifconfig br0 176.9.151.101 netmask 255.255.255.224 broatcast 176.9.151.127
sleep 1
route add default gw 176.9.151.97 eth0
sleep 1
route add default gw 176.9.151.97 br0
As you can see I have to add IP manually.
Here is my uname:
Linux nebula1.compsan.com 2.6.32-504.30.3.el6.x86_64 #1 SMP Wed Jul 15 10:13:09 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
I am using Centos 6.6.
Thx in advance
