I downloaded the Rocky Linux 9 image provided by OpenNebula and created a VM. I have set all network related parameters in the network config. The IP address, netmask etc are all correctly taken over and added to the VM but only ETH0_DNS is not used. After every reboot of the VM looses the DNS config.
Are you issuing reboots from within the VM or from OpenNebula ? You might be able to find clues as why is this the case on the one-context systemd unit reports or at /var/log/messages.
I usually reboot from within the VM. The systemd logs were already rotated. The file /var/log/messages didn’t help much. I see that NetworkManager applied the other things:
Later I see as well that these values are set as default:
NetworkManager[957]: <info> [1702595447.3171] policy: set 'eth0' (eth0) as default for IPv4 routing and DNS
But nowhere is mentioned what happened with the DNS config value. For the “OpenNebula pre-networking contextualization” I see all values that were read in and set e.g.:
