Docker Machine fail with the opennebula Driver
Hi
I’m testing the docker integration with opennebula and i have deployed an environment for this on my opennebula.
I have deployed an opennebula CLI machine based on Ubuntu and there installed the docker-machine, go, godeps binaries and all the exports variables on the system.
root@ubuntu:~# docker-machine version
docker-machine version 0.6.0, build e27fb87
root@ubuntu:~# go version
go version go1.6.2 linux/amd64
root@ubuntu:~# export
declare -x GOPATH="/root/work"
declare -x ONE_XMLRPC=“http://IP:2633
declare -x PATH=”/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/root/work/bin:/usr/local/go/bin"
I have downloaded the image boot2docker from the marketplace and put on my opennebula environment with id 192 and thereis a network with id 4 for use with this image.
My problem come when i try to launch the docker image:
root@ubuntu:~# docker-machine create --driver opennebula --opennebula-network-id 4 --opennebula-image-id 192 --opennebula-data-size 10240 mydockerengine
dial tcp: missing address
And at this point i dont know how could y go on.
I have tried the docker-machine and it seems to works correctly:
root@ubuntu:~# docker-machine ls
NAME ACTIVE DRIVER STATE URL SWARM DOCKER ERRORS
And the ONE commands works correctly:
root@ubuntu:~# onevnet list
ID USER GROUP NAME CLUSTER BRIDGE LEASES
4 oneadmin oneadmin private - br0 21
Whats its the dial tcp:missing address??
It looks like the ONE_XMLRPC variable is not properly set. You should replace IP with the actual IP or hostname.
Hi Jaime
This was an example. The IP is my localserver IP correctly.
I can do any one CLI command from the machine and this means the XML RPC is working, true?
The problem appear with the
Regards!!
Jose Angel Diaz Diaz
Coordinador Tecnologico
Centro de Excelencia de Fuentes Abiertas (CENATIC)
Dirección adjunta de Sistemas de Información
red.es
Edificio Cenatic
Calle Clara Campoamor s/n
06200 Almendralejo. España
Telf: 924 677 316
www.red.es
www.unblogenred.es
