Error after upgrade from 5.12 to 6.0.0.2
the opennebula service is not starting, this is from the log
Aug 04 21:55:28 localhost.localdomain oned[8037]: Error while parsing configuration file:
Aug 04 21:55:28 localhost.localdomain oned[8037]: syntax error, unexpected OBRACKET, expecting STRING at line 83, columns 3284:3290
Aug 04 21:55:28 localhost.localdomain oned[8037]: Could not load nebula configuration file.
Aug 04 21:55:28 localhost.localdomain systemd[1]: opennebula.service: Main process exited, code=exited, status=255/n/a
Aug 04 21:55:28 localhost.localdomain systemd[1]: opennebula.service: Failed with result ‘exit-code’.
any ideas what to look for?
Hello @Liorme,
It seems there is an error in your /etc/one/oned.conf, so please check line 83 (or some around it) to find possible errors.
Best,
Álex.
the yellow one is row 83. maybe the comma at the end of the 5900?
No, that comma is correct, maybe the error is in a different line, you need to check all the configuration file.
Best,
Álex.
