I already have an On Premise cloud implemented with on in version 5.12. However, recently everything stopped working due to a power outage and we lost access to the SQLite database. We did another implementation of Sunstone and other server packages on another server in version 6.8.0. As a result, I’m having trouble connecting to hosts that were running on version 5.12. Also, on other hosts that we recently deployed, which were not on cloud 5.12, I can: Connect to the host, Create VM, and see the resources. However, after the VM is created, I cannot access it. The VM is born, but becomes inaccessible.
The issue is that, although OpenNebula indicates that the VM has an IP, I can’t even ping that IP. I have questions about how to configure the Virtual Network in the best way for the VM to be available. I tried several combinations, but still the VM is not accessible by IP or VNC.
root@torvalds:~# onevm list
ID USER GROUP NAME STAT CPU MEM HOST TIME
60 oneadmin oneadmin 14020 runn 1 2G desktopg04 1d 19h06
Note that the IP is the IP that got assigned to the VM from the address space. For the VM to actually have that IP configured inside the Guest OS you need to make sure the VM as a working contextualization.
