I have 3 local opennebula datastores configured (system, file and image) and other 2 datasets with CEPH as backend. When I try to deploy a VM on the local datastore I get an error: “Error deploying virtual machine 13 to HID: 0. Reason: [one.vm.deploy] Image Datastore does not support transfer mode: ceph”
However the TM in this datastore is configured as ssh. Before adding the CEPH datastore it worked correctly.
The CEPH datastore works correctly.
A
opennebula-common-6.10.0-1.el9.noarch
KVM
RHEL 9.5
tail /var/log/one/sched.log
Thu Jan 30 16:08:44 2025 [Z0][VM][E]: Error deploying virtual machine 13 to HID: 0. Reason: [one.vm.deploy] Image Datastore does not support transfer mode: ceph
Thu Jan 30 16:08:59 2025 [Z0][VM][E]: Error deploying virtual machine 13 to HID: 0. Reason: [one.vm.deploy] Image Datastore does not support transfer mode: ceph
Thu Jan 30 16:09:14 2025 [Z0][VM][E]: Error deploying virtual machine 13 to HID: 0. Reason: [one.vm.deploy] Image Datastore does not support transfer mode: ceph
Thu Jan 30 16:09:30 2025 [Z0][VM][E]: Error deploying virtual machine 13 to HID: 0. Reason: [one.vm.deploy] Image Datastore does not support transfer mode: ceph
onedatastore list
ID NAME SIZE AVA CLUSTERS IMAGES TYPE DS TM STAT
101 cephds 56.5T 99% 0 4 img ceph ceph on
100 ceph_system 56.5T 99% 0 0 sys - ceph on
2 files 69.9G 91% 0 0 fil fs ssh on
1 default 69.9G 91% 0 2 img fs ssh on
0 system - - 0 0 sys - ssh on
onedatastore show 1
DATASTORE 1 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : IMAGE
DS_MAD : fs
TM_MAD : ssh
BASE PATH : /var/lib/one//datastores/1
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : 69.9G
FREE: : 63.4G
USED: : 6.6G
LIMIT: : -
OWNER : um-
GROUP : u–
OTHER : —
DATASTORE TEMPLATE
ALLOW_ORPHANS=“YES”
CLONE_TARGET=“SYSTEM”
DISK_TYPE=“FILE”
DS_MAD=“fs”
LN_TARGET=“SYSTEM”
RESTRICTED_DIRS=“/”
SAFE_DIRS=“/var/tmp”
TM_MAD=“ssh”
TYPE=“IMAGE_DS”
IMAGES
0
13
onevm show 13
VIRTUAL MACHINE 13 INFORMATION
NAME : Rocky Linux 9-13
USER : user1
GROUP : gr1
STATE : DONE
LCM_STATE : LCM_INIT
LOCK : None
RESCHED : No
START TIME : 01/30 14:26:40
END TIME : 01/30 16:09:34
DEPLOY ID : -
VIRTUAL MACHINE MONITORING
OWNER : um-
GROUP : —
OTHER : —
VM DISKS
ID DATASTORE TARGET IMAGE SIZE TYPE SAVE
0 default vda Rocky Linux 9 -/4G file NO
1 - hda CONTEXT -/- - -
USER TEMPLATE
LXD_SECURITY_PRIVILEGED=“true”
SCHED_MESSAGE=“Thu Jan 30 16:09:30 2025: Cannot dispatch VM to any Host. Possible reasons: Not enough capacity in Host or System DS, dispatch limit reached, or limit of free leases reached.”
VIRTUAL MACHINE TEMPLATE
AUTOMATIC_DS_REQUIREMENTS=“("CLUSTERS/ID" @> 0)”
AUTOMATIC_NIC_REQUIREMENTS=“("CLUSTERS/ID" @> 0)”
AUTOMATIC_REQUIREMENTS=“(CLUSTER_ID = 0) & !(PUBLIC_CLOUD = YES) & !(PIN_POLICY = PINNED)”
CONTEXT=[
DISK_ID=“1”,
NETWORK=“YES”,
SSH_PUBLIC_KEY=“”,
TARGET=“hda” ]
CPU=“1”
CPU_MODEL=[
MODEL=“host-passthrough” ]
GRAPHICS=[
LISTEN=“0.0.0.0”,
TYPE=“vnc” ]
MEMORY=“768”
OS=[
ARCH=“x86_64”,
UUID=“04d6402b-0c86-4379-b092-635358886dd7” ]
TEMPLATE_ID=“9”
VMID="13
