Hi forum,
I have installed on a fresh server last version self-contained and everything is ok ( I think ) expect when I issue commands:
oneadmin@sunstone:/var/lib/one/var$ oneuser list
/var/lib/one/lib/ruby/opennebula/client.rb:147:in rstrip!': can't modify frozen String (RuntimeError)* *from /var/lib/one/lib/ruby/opennebula/client.rb:147:ininitialize’
from /var/lib/one/lib/ruby/cli/one_helper.rb:373:in new'* *from /var/lib/one/lib/ruby/cli/one_helper.rb:373:inget_client’
from /var/lib/one/lib/ruby/cli/one_helper.rb:431:in set_client'* *from /var/lib/one/bin/oneuser:43:inblock (2 levels) in '
from /var/lib/one/lib/ruby/cli/command_parser.rb:445:in call'* *from /var/lib/one/lib/ruby/cli/command_parser.rb:445:inrun’
from /var/lib/one/lib/ruby/cli/command_parser.rb:76:in initialize'* *from /var/lib/one/bin/oneuser:36:innew’
from /var/lib/one/bin/oneuser:36:in `’
File client.rb line 147 contains:
@one_endpoint.rstrip!
No erros in logs files. Gem is installed:
oneadmin@sunstone:/root$ gem list
*** LOCAL GEMS ***
amazon-ec2 (0.9.17)
aws-sdk (1.33.0)
azure (0.6.4)
builder (3.2.2)
configparser (0.1.3)
curb (0.8.8)
daemons (1.2.2)
eventmachine (1.0.7)
faraday (0.9.1)
hashie (3.4.1)
inflection (1.0.0)
json (1.8.2)
macaddr (1.7.1)
mime-types (2.5, 1.25.1)
mini_portile (0.6.2)
multi_json (1.11.0)
multipart-post (2.0.0)
mysql (2.9.1)
net-ldap (0.11)
nokogiri (1.6.6.2)
ox (2.2.0)
parse-cron (0.1.4)
polyglot (0.3.5)
rack (1.6.1)
rack-protection (1.5.3)
sequel (4.22.0)
sinatra (1.4.6)
softlayer_api (3.0.2)
sqlite3 (1.3.10)
systemu (2.6.5)
thin (1.6.3)
tilt (2.0.1)
treetop (1.6.2)
trollop (2.1.2)
uuid (2.3.7)
uuidtools (2.1.5)
xml-simple (1.1.5)
zendesk_api (1.7.4)
Best regards.
Francisco
