Error executing image transfer script: Error copying check.openview.info:/var/lib/one//datastores/1/68e5bf72b828d33c4810895cd2c2a7e6 to node1:/var/lib/one//datastores/0/0/disk.0
Usually there is a hint in the logs located up to few lines above or below such message. Common issue is unkwnown host, host key verification failure, etc…
it’s working and thanks for help
