Error to create VM
I try create a VM but i received this error, access using ssh are ok and oneadmin have permission on front and host, but the user oneadmin on host can’t start libvirtd service, return permission denied. Anyone can help me ?
Thu Oct 29 04:36:03 2015 [Z0][DiM][I]: New VM state is ACTIVE.
Thu Oct 29 04:36:03 2015 [Z0][LCM][I]: New VM state is PROLOG.
Thu Oct 29 04:36:03 2015 [Z0][TM][I]: Command execution fail: /var/lib/one/remotes/tm/shared/clone cloudmanager.tudonanuvem.com.br:/var/lib/one//datastores/1/df2e99d0dc224b21d93e726477961761 host.tudonanuvem.com.br:/var/lib/one//datastores/101/9/disk.0 9 1
Thu Oct 29 04:36:03 2015 [Z0][TM][I]: clone: Cloning /var/lib/one/datastores/1/df2e99d0dc224b21d93e726477961761 in host.tudonanuvem.com.br:/var/lib/one//datastores/101/9/disk.0
Thu Oct 29 04:36:03 2015 [Z0][TM][E]: clone: Command “cd /var/lib/one/datastores/101/9; cp /var/lib/one/datastores/1/df2e99d0dc224b21d93e726477961761 /var/lib/one/datastores/101/9/disk.0” failed: cp: cannot stat `/var/lib/one/datastores/1/df2e99d0dc224b21d93e726477961761’: No such file or directory
Thu Oct 29 04:36:03 2015 [Z0][TM][E]: Error copying cloudmanager.tudonanuvem.com.br:/var/lib/one//datastores/1/df2e99d0dc224b21d93e726477961761 to host.tudonanuvem.com.br:/var/lib/one//datastores/101/9/disk.0
Thu Oct 29 04:36:03 2015 [Z0][TM][I]: ExitCode: 1
Thu Oct 29 04:36:03 2015 [Z0][TM][E]: Error executing image transfer script: Error copying cloudmanager.tudonanuvem.com.br:/var/lib/one//datastores/1/df2e99d0dc224b21d93e726477961761 to host.tudonanuvem.com.br:/var/lib/one//datastores/101/9/disk.0
Thu Oct 29 04:36:03 2015 [Z0][DiM][I]: New VM state is FAILED
If you install “opennebula-node” package in the host/node, the sudo privilege will be set accordingly.
Also, make sure you have set the passwordless SSH login.
The ssh passwordless is OK, but what is the configuration i need make on sudo ?
This sudoers configuration works fine for me
create a file in sudoers.d named opennebula with following setting
Defaults !requiretty
Defaults secure_path = /sbin:/bin:/usr/sbin:/usr/bin
Cmnd_Alias ONE_MISC = /bin/dd, /sbin/mkfs, /bin/sync, /bin/nc, /usr/bin/mkfifo, /bin/netcat
Cmnd_Alias ONE_NET = /sbin/brctl, /sbin/ebtables, /sbin/iptables, /sbin/ip, /sbin/vconfig
Cmnd_Alias ONE_LVM = /sbin/lvcreate, /sbin/lvremove, /sbin/lvrename, /sbin/lvs, /sbin/vgdisplay
Cmnd_Alias ONE_ISCSI = /usr/bin/iscsiadm, /usr/sbin/tgt-admin, /usr/sbin/tgtadm
Cmnd_Alias ONE_OVS = /usr/bin/ovs-ofctl, /usr/bin/ovs-vsctl
Cmnd_Alias ONE_XEN = /usr/sbin/xentop, /usr/sbin/xl, /usr/sbin/xm, /usr/bin/ssh
oneadmin ALL=(ALL) NOPASSWD: ONE_MISC, ONE_NET, ONE_LVM, ONE_ISCSI, ONE_OVS, ONE_XEN
I checked and this files exist, with this lines.
Are you using KVM? Make sure you have the following configured correctly (this works at least for Ubuntu hosts):
On host (hypervisor):
cat /etc/udev/rules.d/60-qemu-kvm.rules
KERNEL==“kvm”, GROUP=“oneadmin”, MODE=“0660”
^^ reboot after this to make sure these rules are in affect.
Check /etc/libvirt/libvirtd.conf for these settings:
unix_sock_group = "oneadmin"
unix_sock_ro_perms = "0777"
unix_sock_rw_perms = "0770"
auth_unix_ro = "none"
auth_unix_rw = “none”
Check /etc/libvirt/qemu.conf for these settings:
user = "oneadmin"
group = "oneadmin"
dynamic_ownership = 0
Hi @Daniel_Moura
Me too face this same problem.
When i change All Datastores’s TM_MAD to ssh(Default is shared), it is working fine. Try it.
Don’t work, i tried all, the log:
Tue Nov 3 20:27:05 2015 [Z0][VM][I]: New state is ACTIVE
Tue Nov 3 20:27:05 2015 [Z0][VM][I]: New LCM state is PROLOG
Tue Nov 3 20:27:05 2015 [Z0][TM][I]: Command execution fail: /var/lib/one/remotes/tm/shared/clone cloudmanager.tudonanuvem.com.br:/var/lib/one//datastores/1/eb80b3ebdf6cb4e188a11ebb5d85c87b node.tudonanuvem.com.br:/var/lib/one//datastores/0/0/disk.0 0 1
Tue Nov 3 20:27:05 2015 [Z0][TM][I]: clone: Cloning /var/lib/one/datastores/1/eb80b3ebdf6cb4e188a11ebb5d85c87b in node.tudonanuvem.com.br:/var/lib/one//datastores/0/0/disk.0
Tue Nov 3 20:27:05 2015 [Z0][TM][E]: clone: Command “cd /var/lib/one/datastores/0/0; cp /var/lib/one/datastores/1/eb80b3ebdf6cb4e188a11ebb5d85c87b /var/lib/one/datastores/0/0/disk.0 ; qemu-img resize /var/lib/one/datastores/0/0/disk.0 40960M” failed: cp: cannot stat `/var/lib/one/datastores/1/eb80b3ebdf6cb4e188a11ebb5d85c87b’: No such file or directory
Tue Nov 3 20:27:05 2015 [Z0][TM][I]: Could not open ‘/var/lib/one/datastores/0/0/disk.0’: No such file or directory
Tue Nov 3 20:27:06 2015 [Z0][TM][E]: Error copying cloudmanager.tudonanuvem.com.br:/var/lib/one//datastores/1/eb80b3ebdf6cb4e188a11ebb5d85c87b to node.tudonanuvem.com.br:/var/lib/one//datastores/0/0/disk.0
Tue Nov 3 20:27:06 2015 [Z0][TM][I]: ExitCode: 1
Tue Nov 3 20:27:06 2015 [Z0][TM][E]: Error executing image transfer script: Error copying cloudmanager.tudonanuvem.com.br:/var/lib/one//datastores/1/eb80b3ebdf6cb4e188a11ebb5d85c87b to node.tudonanuvem.com.br:/var/lib/one//datastores/0/0/disk.0
Tue Nov 3 20:27:06 2015 [Z0][VM][I]: New LCM state is PROLOG_FAILURE
IMHO you are still using TM_MAD set as shared at least for the IMAGE datastore. Please change all datastores TM_MAD to ssh as @thomasalrin hinted and try again.
Kind Regards,
i tried but don’t work.
My Front Server is a VM in Host Server, using a internal network, on two sides i use CentOS 6.7 64Bits, don’t have NFS installed, using a local files system on host and frontend. I other opont in /etc/libvirt/qemu.conf if the root user and root group not active, my root don’t start or create a VM.
As Anton pointed out you are using shared drivers in a setup without shared datastores:
Change TM_MAD to shared in both the images and system datastore. You can use this command to do it:
$ onedatastore update <datastore id>
Ops, my bad. Change it to ssh.
I decided put all (frontend and host) in one server, on CentOS 7 only alter the default (images) default path and change owner of this to oneadmin, but now i received this error (using image/template downloaded from frontend):
Wed Nov 4 21:55:27 2015 [Z0][VM][I]: New state is ACTIVE
Wed Nov 4 21:55:27 2015 [Z0][VM][I]: New LCM state is PROLOG
Wed Nov 4 21:55:28 2015 [Z0][TM][I]: Command execution fail: /var/lib/one/remotes/tm/shared/clone node.tudonanuvem.com.br:/storage/isos/1/4d774e622ac2af0223b2a5fa667140e0 node.tudonanuvem.com.br:/var/lib/one//datastores/0/1/disk.0 1 1
Wed Nov 4 21:55:28 2015 [Z0][TM][I]: /var/lib/one/remotes/tm/shared/clone: line 87: [: : integer expression expected
Wed Nov 4 21:55:28 2015 [Z0][TM][I]: clone: Cloning /var/lib/one/datastores/1/4d774e622ac2af0223b2a5fa667140e0 in node.tudonanuvem.com.br:/var/lib/one//datastores/0/1/disk.0
Wed Nov 4 21:55:28 2015 [Z0][TM][E]: clone: Command "cd /var/lib/one/datastores/0/1; cp /var/lib/one/datastores/1/4d774e622ac2af0223b2a5fa667140e0 /var/lib/one/datastores/0/1/disk.0 " failed: Warning: Permanently added ‘node.tudonanuvem.com.br,158.69.119.46’ (ECDSA) to the list of known hosts.
Wed Nov 4 21:55:28 2015 [Z0][TM][I]: cp: cannot stat ‘/var/lib/one/datastores/1/4d774e622ac2af0223b2a5fa667140e0’: No such file or directory
Wed Nov 4 21:55:28 2015 [Z0][TM][E]: Error copying node.tudonanuvem.com.br:/storage/isos/1/4d774e622ac2af0223b2a5fa667140e0 to node.tudonanuvem.com.br:/var/lib/one//datastores/0/1/disk.0
Wed Nov 4 21:55:28 2015 [Z0][TM][I]: ExitCode: 1
Wed Nov 4 21:55:28 2015 [Z0][TM][E]: Error executing image transfer script: Error copying node.tudonanuvem.com.br:/storage/isos/1/4d774e622ac2af0223b2a5fa667140e0 to node.tudonanuvem.com.br:/var/lib/one//datastores/0/1/disk.0
Wed Nov 4 21:55:28 2015 [Z0][VM][I]: New LCM state is PROLOG_FAILURE
Your log shows, you are not yet change the TM_MAD of datastores to ssh. Please change it first
Thomas,
All disks are local disk, the frontend and host (KVM node) are in the same server, single server, if i set ssh, the opennebula don’t find, access the storage. If i set all storage to original path, everything work, but i want store de images and isos in other path.
Hi @Daniel_Moura,
I am feeling lost in your setup…
If you have all in one server the ssh TM_MAD should work. I am developing on 3 nodes, where one of them is ‘all in one’ and have not experienced issues with the ssh TM_MAD to deploy VM on it.
Please provide the output(XML) from the following commands:
onedatastore list -x
onehost list -x
Kind Regards,
If i change to ssh, the openebula don't read the disk information, example the disk size !
onedatastore list -x:
<DATASTORE_POOL>
  <DATASTORE>
    <ID>0</ID>
    <UID>0</UID>
    <GID>0</GID>
    <UNAME>oneadmin</UNAME>
    <GNAME>oneadmin</GNAME>
    <NAME>system</NAME>
    <PERMISSIONS>
      <OWNER_U>1</OWNER_U>
      <OWNER_M>1</OWNER_M>
      <OWNER_A>0</OWNER_A>
      <GROUP_U>1</GROUP_U>
      <GROUP_M>0</GROUP_M>
      <GROUP_A>0</GROUP_A>
      <OTHER_U>0</OTHER_U>
      <OTHER_M>0</OTHER_M>
      <OTHER_A>0</OTHER_A>
    </PERMISSIONS>
    <DS_MAD><![CDATA[-]]></DS_MAD>
    <TM_MAD><![CDATA[shared]]></TM_MAD>
    <BASE_PATH><![CDATA[/var/lib/one//datastores/0]]></BASE_PATH>
    <TYPE>1</TYPE>
    <DISK_TYPE>0</DISK_TYPE>
    <STATE>0</STATE>
    <CLUSTER_ID>-1</CLUSTER_ID>
    <CLUSTER/>
    <TOTAL_MB>535287</TOTAL_MB>
    <FREE_MB>533186</FREE_MB>
    <USED_MB>2101</USED_MB>
    <IMAGES/>
    <TEMPLATE>
      <BASE_PATH><![CDATA[/var/lib/one//datastores/]]></BASE_PATH>
      <SHARED><![CDATA[YES]]></SHARED>
      <TYPE><![CDATA[SYSTEM_DS]]></TYPE>
    </TEMPLATE>
  </DATASTORE>
  <DATASTORE>
    <ID>1</ID>
    <UID>0</UID>
    <GID>0</GID>
    <NAME>default</NAME>
    <PERMISSIONS>
    </PERMISSIONS>
    <DS_MAD><![CDATA[fs]]></DS_MAD>
    <BASE_PATH><![CDATA[/storage/isos/1]]></BASE_PATH>
    <TYPE>0</TYPE>
    <STATE>0</STATE>
    <CLUSTER/>
    <TOTAL_MB>1906669</TOTAL_MB>
    <FREE_MB>1904810</FREE_MB>
    <USED_MB>1860</USED_MB>
    <IMAGES>
      <ID>5</ID>
    </IMAGES>
    <TEMPLATE>
      <BASE_PATH><![CDATA[/storage/isos/]]></BASE_PATH>
      <CLONE_TARGET><![CDATA[SYSTEM]]></CLONE_TARGET>
      <DISK_TYPE><![CDATA[FILE]]></DISK_TYPE>
      <LN_TARGET><![CDATA[NONE]]></LN_TARGET>
      <TYPE><![CDATA[IMAGE_DS]]></TYPE>
    </TEMPLATE>
  </DATASTORE>
  <DATASTORE>
    <ID>2</ID>
    <UID>0</UID>
    <GID>0</GID>
    <NAME>files</NAME>
    <PERMISSIONS>
    </PERMISSIONS>
    <BASE_PATH><![CDATA[/var/lib/one//datastores/2]]></BASE_PATH>
    <TYPE>2</TYPE>
    <STATE>0</STATE>
    <CLUSTER/>
    <FREE_MB>533187</FREE_MB>
    <IMAGES/>
    <TEMPLATE>
      <TYPE><![CDATA[FILE_DS]]></TYPE>
    </TEMPLATE>
  </DATASTORE>
</DATASTORE_POOL>
onehost list -x firs part:
<HOST_POOL>
      <HOST>
        <ID>0</ID>
        <NAME>node.tudonanuvem.com.br</NAME>
        <STATE>2</STATE>
        <IM_MAD><![CDATA[kvm]]></IM_MAD>
        <VM_MAD><![CDATA[kvm]]></VM_MAD>
        <VN_MAD><![CDATA[dummy]]></VN_MAD>
        <LAST_MON_TIME>1446742926</LAST_MON_TIME>
        <CLUSTER/>
        <HOST_SHARE>
          <DISK_USAGE>0</DISK_USAGE>
          <MEM_USAGE>786432</MEM_USAGE>
          <CPU_USAGE>100</CPU_USAGE>
          <MAX_DISK>535287</MAX_DISK>
          <MAX_MEM>32678040</MAX_MEM>
          <MAX_CPU>800</MAX_CPU>
          <FREE_DISK>533186</FREE_DISK>
          <FREE_MEM>32068560</FREE_MEM>
          <FREE_CPU>800</FREE_CPU>
          <USED_DISK>2102</USED_DISK>
          <USED_MEM>609480</USED_MEM>
          <USED_CPU>0</USED_CPU>
          <RUNNING_VMS>1</RUNNING_VMS>
          <DATASTORES/>
          <PCI_DEVICES>
            <PCI>
              <ADDRESS><![CDATA[0000:00:00:0]]></ADDRESS>
              <BUS><![CDATA[00]]></BUS>
              <CLASS><![CDATA[0600]]></CLASS>
              <CLASS_NAME><![CDATA[Host bridge]]></CLASS_NAME>
              <DEVICE><![CDATA[6f00]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell DMI2]]></DEVICE_NAME>
              <DOMAIN><![CDATA[0000]]></DOMAIN>
              <FUNCTION><![CDATA[0]]></FUNCTION>
              <SHORT_ADDRESS><![CDATA[00:00.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[00]]></SLOT>
              <TYPE><![CDATA[8086:6f00:0600]]></TYPE>
              <VENDOR><![CDATA[8086]]></VENDOR>
              <VENDOR_NAME><![CDATA[Intel Corporation]]></VENDOR_NAME>
              <VMID><![CDATA[-1]]></VMID>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:01:0]]></ADDRESS>
              <CLASS><![CDATA[0604]]></CLASS>
              <CLASS_NAME><![CDATA[PCI bridge]]></CLASS_NAME>
              <DEVICE><![CDATA[6f02]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell PCI Express Root Port 1]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:01.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[01]]></SLOT>
              <TYPE><![CDATA[8086:6f02:0604]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:02:0]]></ADDRESS>
              <DEVICE><![CDATA[6f04]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell PCI Express Root Port 2]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:02.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[02]]></SLOT>
              <TYPE><![CDATA[8086:6f04:0604]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:02:2]]></ADDRESS>
              <DEVICE><![CDATA[6f06]]></DEVICE>
              <FUNCTION><![CDATA[2]]></FUNCTION>
              <SHORT_ADDRESS><![CDATA[00:02.2]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f06:0604]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:03:0]]></ADDRESS>
              <DEVICE><![CDATA[6f08]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell PCI Express Root Port 3]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:03.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[03]]></SLOT>
              <TYPE><![CDATA[8086:6f08:0604]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:05:0]]></ADDRESS>
              <CLASS><![CDATA[0880]]></CLASS>
              <CLASS_NAME><![CDATA[System peripheral]]></CLASS_NAME>
              <DEVICE><![CDATA[6f28]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell Adress Map/VTd_Misc/System Management]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:05.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[05]]></SLOT>
              <TYPE><![CDATA[8086:6f28:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:05:1]]></ADDRESS>
              <DEVICE><![CDATA[6f29]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell IIO Hot Plug]]></DEVICE_NAME>
              <FUNCTION><![CDATA[1]]></FUNCTION>
              <SHORT_ADDRESS><![CDATA[00:05.1]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f29:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:05:2]]></ADDRESS>
              <DEVICE><![CDATA[6f2a]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell IIO RAS/Control Status/Global Errors]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:05.2]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f2a:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:05:4]]></ADDRESS>
              <CLASS><![CDATA[0800]]></CLASS>
              <CLASS_NAME><![CDATA[PIC]]></CLASS_NAME>
              <DEVICE><![CDATA[6f2c]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell I/O APIC]]></DEVICE_NAME>
              <FUNCTION><![CDATA[4]]></FUNCTION>
              <SHORT_ADDRESS><![CDATA[00:05.4]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f2c:0800]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:14:0]]></ADDRESS>
              <CLASS><![CDATA[0c03]]></CLASS>
              <CLASS_NAME><![CDATA[USB controller]]></CLASS_NAME>
              <DEVICE><![CDATA[8c31]]></DEVICE>
              <DEVICE_NAME><![CDATA[8 Series/C220 Series Chipset Family USB xHCI]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:14.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[14]]></SLOT>
              <TYPE><![CDATA[8086:8c31:0c03]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:16:0]]></ADDRESS>
              <CLASS><![CDATA[0780]]></CLASS>
              <CLASS_NAME><![CDATA[Communication controller]]></CLASS_NAME>
              <DEVICE><![CDATA[8c3a]]></DEVICE>
              <DEVICE_NAME><![CDATA[8 Series/C220 Series Chipset Family MEI Controller #1]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:16.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[16]]></SLOT>
              <TYPE><![CDATA[8086:8c3a:0780]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:16:1]]></ADDRESS>
              <DEVICE><![CDATA[8c3b]]></DEVICE>
              <DEVICE_NAME><![CDATA[8 Series/C220 Series Chipset Family MEI Controller #2]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:16.1]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:8c3b:0780]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:1a:0]]></ADDRESS>
              <DEVICE><![CDATA[8c2d]]></DEVICE>
              <DEVICE_NAME><![CDATA[8 Series/C220 Series Chipset Family USB EHCI #2]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:1a.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[1a]]></SLOT>
              <TYPE><![CDATA[8086:8c2d:0c03]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:1c:0]]></ADDRESS>
              <DEVICE><![CDATA[8c10]]></DEVICE>
              <DEVICE_NAME><![CDATA[8 Series/C220 Series Chipset Family PCI Express Root Port #1]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:1c.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[1c]]></SLOT>
              <TYPE><![CDATA[8086:8c10:0604]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:1c:4]]></ADDRESS>
              <DEVICE><![CDATA[8c18]]></DEVICE>
              <DEVICE_NAME><![CDATA[8 Series/C220 Series Chipset Family PCI Express Root Port #5]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:1c.4]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:8c18:0604]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:1d:0]]></ADDRESS>
              <DEVICE><![CDATA[8c26]]></DEVICE>
              <DEVICE_NAME><![CDATA[8 Series/C220 Series Chipset Family USB EHCI #1]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:1d.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[1d]]></SLOT>
              <TYPE><![CDATA[8086:8c26:0c03]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:1f:0]]></ADDRESS>
              <CLASS><![CDATA[0601]]></CLASS>
              <CLASS_NAME><![CDATA[ISA bridge]]></CLASS_NAME>
              <DEVICE><![CDATA[8c54]]></DEVICE>
              <DEVICE_NAME><![CDATA[C224 Series Chipset Family Server Standard SKU LPC Controller]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:1f.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[1f]]></SLOT>
              <TYPE><![CDATA[8086:8c54:0601]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:1f:2]]></ADDRESS>
              <CLASS><![CDATA[0104]]></CLASS>
              <CLASS_NAME><![CDATA[RAID bus controller]]></CLASS_NAME>
              <DEVICE><![CDATA[2826]]></DEVICE>
              <DEVICE_NAME><![CDATA[C600/X79 series chipset SATA RAID Controller]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[00:1f.2]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:2826:0104]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:1f:3]]></ADDRESS>
              <CLASS><![CDATA[0c05]]></CLASS>
              <CLASS_NAME><![CDATA[SMBus]]></CLASS_NAME>
              <DEVICE><![CDATA[8c22]]></DEVICE>
              <DEVICE_NAME><![CDATA[8 Series/C220 Series Chipset Family SMBus Controller]]></DEVICE_NAME>
              <FUNCTION><![CDATA[3]]></FUNCTION>
              <SHORT_ADDRESS><![CDATA[00:1f.3]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:8c22:0c05]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:00:1f:6]]></ADDRESS>
              <CLASS><![CDATA[1180]]></CLASS>
              <CLASS_NAME><![CDATA[Signal processing controller]]></CLASS_NAME>
              <DEVICE><![CDATA[8c24]]></DEVICE>
              <DEVICE_NAME><![CDATA[8 Series Chipset Family Thermal Management Controller]]></DEVICE_NAME>
              <FUNCTION><![CDATA[6]]></FUNCTION>
              <SHORT_ADDRESS><![CDATA[00:1f.6]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:8c24:1180]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:02:00:0]]></ADDRESS>
              <BUS><![CDATA[02]]></BUS>
              <DEVICE><![CDATA[6f50]]></DEVICE>
              <DEVICE_NAME><![CDATA[Device]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[02:00.0]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f50:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:02:00:1]]></ADDRESS>
              <DEVICE><![CDATA[6f51]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[02:00.1]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f51:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:02:00:2]]></ADDRESS>
              <DEVICE><![CDATA[6f52]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[02:00.2]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f52:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:02:00:3]]></ADDRESS>
              <DEVICE><![CDATA[6f53]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[02:00.3]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f53:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:03:00:0]]></ADDRESS>
              <BUS><![CDATA[03]]></BUS>
              <CLASS><![CDATA[0200]]></CLASS>
              <CLASS_NAME><![CDATA[Ethernet controller]]></CLASS_NAME>
              <DEVICE><![CDATA[15ad]]></DEVICE>
              <DEVICE_NAME><![CDATA[Ethernet Connection X552/X557-AT 10GBASE-T]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[03:00.0]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:15ad:0200]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:03:00:1]]></ADDRESS>
              <SHORT_ADDRESS><![CDATA[03:00.1]]></SHORT_ADDRESS>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:06:00:0]]></ADDRESS>
              <BUS><![CDATA[06]]></BUS>
              <DEVICE><![CDATA[1150]]></DEVICE>
              <DEVICE_NAME><![CDATA[AST1150 PCI-to-PCI Bridge]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[06:00.0]]></SHORT_ADDRESS>
              <TYPE><![CDATA[1a03:1150:0604]]></TYPE>
              <VENDOR><![CDATA[1a03]]></VENDOR>
              <VENDOR_NAME><![CDATA[ASPEED Technology, Inc.]]></VENDOR_NAME>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:07:00:0]]></ADDRESS>
              <BUS><![CDATA[07]]></BUS>
              <CLASS><![CDATA[0300]]></CLASS>
              <CLASS_NAME><![CDATA[VGA compatible controller]]></CLASS_NAME>
              <DEVICE><![CDATA[2000]]></DEVICE>
              <DEVICE_NAME><![CDATA[ASPEED Graphics Family]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[07:00.0]]></SHORT_ADDRESS>
              <TYPE><![CDATA[1a03:2000:0300]]></TYPE>
            </PCI>
onehost list -x second part:
<PCI>
              <ADDRESS><![CDATA[0000:ff:0b:0]]></ADDRESS>
              <BUS><![CDATA[ff]]></BUS>
              <DEVICE><![CDATA[6f81]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell R3 QPI Link 0/1]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:0b.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[0b]]></SLOT>
              <TYPE><![CDATA[8086:6f81:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0b:1]]></ADDRESS>
              <CLASS><![CDATA[1101]]></CLASS>
              <CLASS_NAME><![CDATA[Performance counters]]></CLASS_NAME>
              <DEVICE><![CDATA[6f36]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:0b.1]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f36:1101]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0b:2]]></ADDRESS>
              <DEVICE><![CDATA[6f37]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:0b.2]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f37:1101]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0b:3]]></ADDRESS>
              <DEVICE><![CDATA[6f76]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell R3 QPI Link Debug]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:0b.3]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f76:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0c:0]]></ADDRESS>
              <DEVICE><![CDATA[6fe0]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell Caching Agent]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:0c.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[0c]]></SLOT>
              <TYPE><![CDATA[8086:6fe0:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0c:1]]></ADDRESS>
              <DEVICE><![CDATA[6fe1]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:0c.1]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6fe1:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0c:2]]></ADDRESS>
              <DEVICE><![CDATA[6fe2]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:0c.2]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6fe2:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0c:3]]></ADDRESS>
              <DEVICE><![CDATA[6fe3]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:0c.3]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6fe3:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0f:0]]></ADDRESS>
              <DEVICE><![CDATA[6ff8]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:0f.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[0f]]></SLOT>
              <TYPE><![CDATA[8086:6ff8:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0f:4]]></ADDRESS>
              <DEVICE><![CDATA[6ffc]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:0f.4]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6ffc:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0f:5]]></ADDRESS>
              <DEVICE><![CDATA[6ffd]]></DEVICE>
              <FUNCTION><![CDATA[5]]></FUNCTION>
              <SHORT_ADDRESS><![CDATA[ff:0f.5]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6ffd:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:0f:6]]></ADDRESS>
              <DEVICE><![CDATA[6ffe]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:0f.6]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6ffe:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:10:0]]></ADDRESS>
              <DEVICE><![CDATA[6f1d]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell R2PCIe Agent]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:10.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[10]]></SLOT>
              <TYPE><![CDATA[8086:6f1d:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:10:1]]></ADDRESS>
              <DEVICE><![CDATA[6f34]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:10.1]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f34:1101]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:10:5]]></ADDRESS>
              <DEVICE><![CDATA[6f1e]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell Ubox]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:10.5]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f1e:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:10:6]]></ADDRESS>
              <DEVICE><![CDATA[6f7d]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:10.6]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f7d:1101]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:10:7]]></ADDRESS>
              <DEVICE><![CDATA[6f1f]]></DEVICE>
              <FUNCTION><![CDATA[7]]></FUNCTION>
              <SHORT_ADDRESS><![CDATA[ff:10.7]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f1f:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:12:0]]></ADDRESS>
              <DEVICE><![CDATA[6fa0]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell Home Agent 0]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:12.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[12]]></SLOT>
              <TYPE><![CDATA[8086:6fa0:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:12:1]]></ADDRESS>
              <DEVICE><![CDATA[6f30]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:12.1]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f30:1101]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:13:0]]></ADDRESS>
              <DEVICE><![CDATA[6fa8]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell Memory Controller 0 - Target Address/Thermal/RAS]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:13.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[13]]></SLOT>
              <TYPE><![CDATA[8086:6fa8:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:13:1]]></ADDRESS>
              <DEVICE><![CDATA[6f71]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:13.1]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f71:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:13:2]]></ADDRESS>
              <DEVICE><![CDATA[6faa]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell Memory Controller 0 - Channel Target Address Decoder]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:13.2]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6faa:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:13:3]]></ADDRESS>
              <DEVICE><![CDATA[6fab]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:13.3]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6fab:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:13:4]]></ADDRESS>
              <DEVICE><![CDATA[6fac]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:13.4]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6fac:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:13:5]]></ADDRESS>
              <DEVICE><![CDATA[6fad]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:13.5]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6fad:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:13:6]]></ADDRESS>
              <DEVICE><![CDATA[6fae]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell DDRIO Channel 0/1 Broadcast]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:13.6]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6fae:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:13:7]]></ADDRESS>
              <DEVICE><![CDATA[6faf]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell DDRIO Global Broadcast]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:13.7]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6faf:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:1e:0]]></ADDRESS>
              <DEVICE><![CDATA[6f98]]></DEVICE>
              <DEVICE_NAME><![CDATA[Broadwell Power Control Unit]]></DEVICE_NAME>
              <SHORT_ADDRESS><![CDATA[ff:1e.0]]></SHORT_ADDRESS>
              <SLOT><![CDATA[1e]]></SLOT>
              <TYPE><![CDATA[8086:6f98:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:1e:1]]></ADDRESS>
              <DEVICE><![CDATA[6f99]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:1e.1]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f99:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:1e:2]]></ADDRESS>
              <DEVICE><![CDATA[6f9a]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:1e.2]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f9a:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:1e:3]]></ADDRESS>
              <DEVICE><![CDATA[6fc0]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:1e.3]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6fc0:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:1e:4]]></ADDRESS>
              <DEVICE><![CDATA[6f9c]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:1e.4]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f9c:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:1f:0]]></ADDRESS>
              <DEVICE><![CDATA[6f88]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:1f.0]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f88:0880]]></TYPE>
            </PCI>
            <PCI>
              <ADDRESS><![CDATA[0000:ff:1f:2]]></ADDRESS>
              <DEVICE><![CDATA[6f8a]]></DEVICE>
              <SHORT_ADDRESS><![CDATA[ff:1f.2]]></SHORT_ADDRESS>
              <TYPE><![CDATA[8086:6f8a:0880]]></TYPE>
            </PCI>
          </PCI_DEVICES>
        </HOST_SHARE>
        <VMS>
          <ID>3</ID>
        </VMS>
        <TEMPLATE>
          <CPUSPEED><![CDATA[1587]]></CPUSPEED>
          <HOSTNAME><![CDATA[node.tudonanuvem.com.br]]></HOSTNAME>
          <HYPERVISOR><![CDATA[kvm]]></HYPERVISOR>
          <MODELNAME><![CDATA[Intel(R) Xeon(R) CPU D-1520 @ 2.20GHz]]></MODELNAME>
          <NETRX><![CDATA[0]]></NETRX>
          <NETTX><![CDATA[0]]></NETTX>
          <RESERVED_CPU><![CDATA[]]></RESERVED_CPU>
          <RESERVED_MEM><![CDATA[]]></RESERVED_MEM>
          <VERSION><![CDATA[4.14.0]]></VERSION>
        </TEMPLATE>
      </HOST>
    </HOST_POOL>
Hi @Daniel_Moura,
I am almost sure that you are hitting something in the tm/shared/clone.
I think there are at least two solutions:
(1) Please try to create the following symlink:
ln -s /storage/isos/1 /var/lib/one/datastores/1
This should workaround the ‘thing’ you are hitting in the shared clone script.
(2) Change TM_MAD to ssh for all datastores - images, system and files. Allow password-less ssh for the oneadmin user to oneadmin@node.tudonanuvem.com.br (itself) and check the oneadmin rigts on /storage/isos/1
Could someone explain what is the meaning of line https://github.com/OpenNebula/one/blob/master/src/tm_mad/shared/clone#L55? I can decode the bash code, but can’t understand why this construction is needed? I could almost bet that there is a bug.
Kind Regards,
