External HTTP Market Place error
After reading the manual and searching the forum I’ve got the place where I need help. I am using the http driver to create a new Market Place. I get this error when I try to send an image to it.
“Wed Mar 25 15:48:44 2020 : Error importing app into marketplace: Error exporting image to file: -”
I am using Apache on the server as recommended in the instructions. I am using a separate sever for this. The directory I am try to write to is set to 777 and the apache process is the owner.
here is the configuration for the Market Place:
BASE_URL = “http://dvdl-mktplace”
BRIDGE_LIST = “dvdl-mktplace”
MARKET_MAD = “http”
PUBLIC_DIR = “market”
I’ve checked and DNS is working.
Has anyone made an HTTP marketplace and can help with this? Is there I log I can look in to see more information on the error above?
John
Check logs from /var/log/one/oned.log, you’ll see something like
Command execution failed (exit code: 255): /var/lib/one/remotes/ **market** /http/monitor {{ base64 template }}
and the error on the next line.
Thanks I’ll dig around in there and see what I can work out,.
Well I found the errror adn am unable to make any sense of it. Is there someone out there who can?
Fri Mar 27 09:33:18 2020 [Z0][ReM][D]: Req:3120 UID:0 one.marketapp.allocate result SUCCESS, 109
Fri Mar 27 09:33:18 2020 [Z0][ReM][D]: Req:9360 UID:0 IP:127.0.0.1 one.marketapp.info invoked , 109
Fri Mar 27 09:33:18 2020 [Z0][ReM][D]: Req:9360 UID:0 one.marketapp.info result SUCCESS, “…”
Fri Mar 27 09:33:18 2020 [Z0][MKP][I]: Command execution failed (exit code: 1): /var/lib/one/remotes/datastore/fs/export 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 109
Fri Mar 27 09:33:18 2020 [Z0][MKP][E]: Error importing app into marketplace: Error exporting image to file: -
Fri Mar 27 09:33:18 2020 [Z0][ReM][D]: Req:6720 UID:0 IP:127.0.0.1 one.zone.raftstatus invoked
Fri Mar 27 09:33:18 2020 [Z0][ReM][D]: Req:6720 UID:0 one.zone.raftstatus result SUCCESS, “<SERVER_ID>-1<…”
Fri Mar 27 09:33:18 2020 [Z0][ReM][D]: Req:8448 UID:0 IP:127.0.0.1 one.vmpool.info invoked , -2, -1, -1, -1
Fri Mar 27 09:33:18 2020 [Z0][ReM][D]: Req:8448 UID:0 one.vmpool.info result SUCCESS, “<VM_POOL>119…”
Fri Mar 27 09:33:18 2020 [Z0][ReM][D]: Req:8944 UID:0 IP:127.0.0.1 one.vmpool.info invoked , -2, -1, -1, -1
Fri Mar 27 09:33:18 2020 [Z0][ReM][D]: Req:8944 UID:0 one.vmpool.info result SUCCESS, “<VM_POOL>119…”
Fri Mar 27 09:33:19 2020 [Z0][AuM][D]: Message received: AUTHENTICATE SUCCESS 460261 -
Try find smth with this error, aspecially
yes that shows up right right after the big block of text and no further explanation as to why.
A quick update. Turns out this error message was caused by trying to export an image from a datastore that was dismounted :-(. Upon choosing another image from a mounted data store we get a new error.
Tue Apr 14 09:55:56 2020 : Error importing app into marketplace: Error dumping /var/lib/one//datastores/1/2daa48aa5b452857b15b07b357f3b15e to dvdl-mktplace:/var/www/html/market/5ade197e703662e1bcba461143755651
We’ll continue to work on this and I’ll update this when we have a solution.
