Hi all,
I’ve setup a federation with one master & one slave zone by following http://docs.opennebula.org/5.2/advanced_components/data_center_federation/federationconfig.html. All seem ok when logged on to the master. Slave zone can be accessed and managed through master sunstone.
However I can not log on directly to the slave zone sunstone.
If I try with correct oneadmin username&password the web interface gives:
OpenNebula is not running or there was a server exception. Please check the server logs. with wrong username&password, it says: Invalid username or password (as expected)
sunstone.log (with incorrect credentials):
Tue Mar 28 11:50:04 2017 [E]: User oneadmin could not be authenticated
Tue Mar 28 11:50:04 2017 [E]: [UserInfo] User couldn’t be authenticated, aborting call.
Tue Mar 28 11:50:04 2017 [I]: Unauthorized login attempt
Tue Mar 28 11:50:04 2017 [I]: xxx.xxx.xxx.xxx - - [28/Mar/2017:11:50:04 +0300] “POST /login HTTP/1.1” 401 - 0.0099
sunstone.log (with correct cred.):
Tue Mar 28 11:51:44 2017 [E]: [UserInfo] User couldn’t be authenticated, aborting call.
Tue Mar 28 11:51:44 2017 [I]: xxx.xxx.xxx.xxx - - [28/Mar/2017:11:51:44 +0300] “POST /login HTTP/1.1” 500 - 0.1352
oned.log (with incorrect cred.)
Tue Mar 28 11:54:44 2017 [Z100][ReM][D]: Req:3200 UID:-1 UserInfo invoked , -1
Tue Mar 28 11:54:44 2017 [Z100][ReM][E]: Req:3200 UID:- UserInfo result FAILURE [UserInfo] User couldn’t be authenticated, aborting call.
oned.log (with correct cred.)
Tue Mar 28 11:55:51 2017 [Z100][AuM][D]: Message received: LOG I 185 Command execution fail: /var/lib/one/remotes/auth/server_cipher/authenticate serveradmin f604c06ab03f5b9f26dfb5b1f473e24e039a0050 ****
Tue Mar 28 11:55:51 2017 [Z100][AuM][I]: Command execution fail: /var/lib/one/remotes/auth/server_cipher/authenticate serveradmin f604c06ab03f5b9f26dfb5b1f473e24e039a0050 ****
Tue Mar 28 11:55:51 2017 [Z100][AuM][D]: Message received: LOG E 185 bad decrypt
Tue Mar 28 11:55:51 2017 [Z100][AuM][I]: bad decrypt
Tue Mar 28 11:55:51 2017 [Z100][AuM][D]: Message received: LOG I 185 ExitCode: 255
Tue Mar 28 11:55:51 2017 [Z100][AuM][I]: ExitCode: 255
Tue Mar 28 11:55:51 2017 [Z100][AuM][D]: Message received: AUTHENTICATE FAILURE 185 bad decrypt
Tue Mar 28 11:55:51 2017 [Z100][AuM][E]: Auth Error: bad decrypt
Tue Mar 28 11:55:51 2017 [Z100][ReM][D]: Req:1200 UID:-1 UserInfo invoked , -1
Tue Mar 28 11:55:51 2017 [Z100][ReM][E]: Req:1200 UID:- UserInfo result FAILURE [UserInfo] User couldn’t be authenticated, aborting call.
Any idea?
Thanks,
Orhan
with sha1 hash of the value in /var/lib/one/.one/one_auth and they match (as expected, otherwise i couldnt be able to login to master because there’s just one oneadmin)
