Hello, ONe developers,
one of my users lost his data using ONe on top of Ceph, after he used “Flatten snapshot”. It seems that this action reverts to the last snapshot instead of keeping the current data, as we expected. Steps to reproduce:
- create a Linux VM
- create an empty datablock image on top of Ceph datastore, make it persistent
- attach the image to the VM, let’s say as
/dev/sdc - inside the VM, run
# echo before snapshot > /dev/sdc ; sync - in Sunstone, open the VM and its Storage tab, click on a camera icon in the /dev/sdc row to create snapshot, name it “snap1”
# echo after snapshot 1 > /dev/sdc ; sync - in Sunstone, open the VM and its Storage tab, click on a camera icon in the /dev/sdc row to create snapshot, name it “snap2”
# echo after snapshot 2 > /dev/sdc ; sync - in Sunstone, detach the /dev/sdc from the VM
- in Sunstone, open the Storage/Images list in the left panel (User view), select the image, open its “Snapshots” tab, select the latest possible snapshot (snap2), and click on “flatten”
- after the image is flattened, attach it to the VM again
# head -n 1 /dev/sdc
Expected behaviour: after snapshot 2
Observed behaviour: after snapshot 1
(in case it is correct, then what is the difference to reverting to the snapshot?)
Anyway, what the user wanted to do was to enlarge the image in question, and Sunstone complained that image with snapshots cannot be resized. At the Ceph level, there is no reason for it, it is possible to resize even the image with snapshots:
# rbd --pool one snap list one-668
SNAPID NAME SIZE TIMESTAMP
1012 0 10GiB Tue Dec 11 11:26:39 2018
# rbd --pool one resize one-668 --size 11G
Resizing image: 100% complete...done.
# rbd --pool one info one-668
rbd image 'one-668':
size 11GiB in 2816 objects
Can the limitation of resizing the image with snapshots be removed? And, if possible, the “flatten image” to be modified to keep the latest data?
Thanks,
-Yenya
