Hello, I setup frontend HA using new RAFT, but today its break.n I see in logs this error messages:
This messages shows also after cluster rebuild…Cluster breaks because of heartbeat from leader timeout, but it was not possible to make candidate leader, because of older log that was on original leader…
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214376 loaded incorrectly. Record index: 214377 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214377 loaded incorrectly. Record index: 214378 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214378 loaded incorrectly. Record index: 214379 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214379 loaded incorrectly. Record index: 214380 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214380 loaded incorrectly. Record index: 214381 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214381 loaded incorrectly. Record index: 214382 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214382 loaded incorrectly. Record index: 214383 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214383 loaded incorrectly. Record index: 214384 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214384 loaded incorrectly. Record index: 214385 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214385 loaded incorrectly. Record index: 214386 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214386 loaded incorrectly. Record index: 214387 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214387 loaded incorrectly. Record index: 214388 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214388 loaded incorrectly. Record index: 214389 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214389 loaded incorrectly. Record index: 214390 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214390 loaded incorrectly. Record index: 214391 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214391 loaded incorrectly. Record index: 214392 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214392 loaded incorrectly. Record index: 214393 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214393 loaded incorrectly. Record index: 214394 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214394 loaded incorrectly. Record index: 214395 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:14 2017 [Z0][DBM][E]: Log record 214395 loaded incorrectly. Record index: 214396 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214396 loaded incorrectly. Record index: 214397 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214397 loaded incorrectly. Record index: 214398 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214398 loaded incorrectly. Record index: 214399 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214399 loaded incorrectly. Record index: 214400 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214400 loaded incorrectly. Record index: 214401 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214401 loaded incorrectly. Record index: 214402 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214402 loaded incorrectly. Record index: 214403 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214403 loaded incorrectly. Record index: 214404 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214404 loaded incorrectly. Record index: 214405 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214405 loaded incorrectly. Record index: 214406 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214406 loaded incorrectly. Record index: 214407 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214407 loaded incorrectly. Record index: 214408 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214408 loaded incorrectly. Record index: 214409 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214409 loaded incorrectly. Record index: 214410 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:13:15 2017 [Z0][DBM][E]: Log record 214410 loaded incorrectly. Record index: 214411 fed. index: 0 sql command: . Operation return code: 0
Mon Jul 31 16:23:13 2017 [Z0][DBM][E]: Tried to modify DB being a follower
Mon Jul 31 16:23:13 2017 [Z0][VMM][D]: VM 12076 successfully monitored: STATE=a CPU=11.02 MEMORY=6291456 NETRX=22408896196 NETTX=36944377281 DISKRDBYTES=6077210624 DISKWRBYTES=208243122176 DISKRDIOPS=328536 DISKWRIOPS=16799112
Mon Jul 31 16:23:13 2017 [Z0][VMM][D]: VM 12489 successfully monitored: STATE=a CPU=0.0 MEMORY=1112768 NETRX=300076514 NETTX=61397844 DISKRDBYTES=137257984 DISKWRBYTES=9631357952 DISKRDIOPS=6900 DISKWRIOPS=1806029
Mon Jul 31 16:23:13 2017 [Z0][VMM][D]: VM 12517 successfully monitored: STATE=a CPU=0.0 MEMORY=604396 NETRX=116811657 NETTX=9502814 DISKRDBYTES=288135452 DISKWRBYTES=1499089920 DISKRDIOPS=9344 DISKWRIOPS=237838
Mon Jul 31 16:23:13 2017 [Z0][VMM][D]: VM 12518 successfully monitored: STATE=a CPU=0.0 MEMORY=2097152 NETRX=110114539 NETTX=52435106 DISKRDBYTES=472254808 DISKWRBYTES=630342656 DISKRDIOPS=24716 DISKWRIOPS=21192
Mon Jul 31 16:23:13 2017 [Z0][VMM][D]: VM 12519 successfully monitored: STATE=a CPU=0.0 MEMORY=2097152 NETRX=80919107 NETTX=24123289 DISKRDBYTES=472140120 DISKWRBYTES=632419328 DISKRDIOPS=24700 DISKWRIOPS=21357
Error connecting but host is running
Error requesting vote from follower 2:HTTP POST to URL 'http://192.168.2.53:2633/RPC2' failed. libcurl failed even to execute the HTTP transaction, explaining: Operation timed out after 3003 milliseconds with 0 out of -1 bytes received
