After attempting numerous times to deploy the GitLab appliance from the marketplace ( https://marketplace.opennebula.io/appliance/6b54a412-03a5-11e9-8652-f0def1753696 ) I cannot get past the login page.
I am not currently configuring SSL/HTTPS - this is all HTTP, so I am leaving the relevant contextualization entries blank.
The appliance appears to deploy correctly, shows as “All set and ready to serve” on the console, and the logfiles in etc/one-appliance don’t show any errors.
However, upon connecting to the URL, the login page takes multiple minutes to load - and then when it does appear, the formatting is horribly broken - Times New Roman font, no layout information (but weirdly the logo appears!). I can try to login, but again, after a looooong time (5 minutes+?) it eventually gives me a 401 page - again with logo, but this time with better formatting.
Initially I believed this was a peformance problem, but I’ve now deployed this onto a fast NFS server (I can see relatively low disk latency and no queuing) and it has 24GB of RAM and 4 vCPUs. It’s not resource starved.
The Hypervisor is KVM on Centos7. I’ve tried using a variety of network configurations (vxlan + vrouter, adding it to the management VLAN) but I seem to get the same result. Can anyone suggest what I am missing?
GitLab Appliance 13.0.5-5.12.0-1.20200609
OpenNebula 5.10.1
Centos 7
Using iguane TF provider:
resource "opennebula_image" "GitLab" {
name = "GitLab - KVM"
description = "CentOS 7 based GitLab CE appliance"
datastore_id = 1
persistent = false
lock = "UNLOCK"
path = "https://marketplace.opennebula.io//appliance/6b54a412-03a5-11e9-8652-f0def1753696/download/0"
dev_prefix = "vd"
driver = "qcow2"
permissions = "660"
group = var.one_target_group
resource "opennebula_template" "GitLabSrvTemplate" {
name = "GitLab Server"
template = templatefile("${path.module}/gitlab_srv.tmpl", {
hostname = local.gitlab_name
domain = var.domain
vcpu = 4
cpu = "4.0"
mbram = "18000"
oneapp_site_hostname = "${local.gitlab_name}.${var.domain}"
oneapp_admin_username = "theusername"
oneapp_admin_password = "secretpassword"
oneapp_admin_email = "geunine@email.provider"
permissions = "660"
resource "opennebula_virtual_machine" "GitLabSrv" {
permissions = "660"
template_id = opennebula_template.GitLabSrvTemplate.id
nic {
model = "virtio"
network_id = var.subnet_id
I will try fixing that and see what happens, but I don’t think that is the cause.
