I believe if I’m correct, if you rename the VM in vCenter, when you try to delete it from OpenNebula, it will send the command and assume vCenter deleted it, but it will still exist, but the machine will disappear from OpenNebula. I’ve done this with 5.4 and below. Just create a VM, once it’s instantiated, rename it in vCenter, then delete it from OpenNebula.
yeah, i know what you mean
my workaround so far, is to limit the permissions of the vcenter user so it can’t delete vms or datastores, which works, but it’s a little “dirty”
the end result is when i trash the vm, it powers off but stays intact
