One of my OpenNebula setups has an issue that I can’t start VMs bound to the host’s ocal storage. I’m a bot at loss as to how to debug this.
Cluster 100 consists of 6 hosts, datastore 102 is of type ssh (to utilize host-local storage). I can happily instantiate VMs with shared storage (datastore 0) on or migrate them to all hosts, but deplyoing to host thu* onto datastore 102 somehow fails. See “lfs-” VMs in this screenshot:
If I grep for e. g. VM 38’s logentries, I only get these:
root@one-1:~# grep " 38" /var/log/one/oned.log | grep "Thu Feb 23 10:" | more
Thu Feb 23 10:10:20 2017 [Z0][ReM][D]: Req:2016 UID:0 TemplateInstantiate result SUCCESS, 38
Thu Feb 23 10:11:33 2017 [Z0][ReM][D]: Req:832 UID:0 VirtualMachineDeploy invoked , 38, 4, false, 102
Thu Feb 23 10:11:33 2017 [Z0][DiM][D]: Deploying VM 38
Thu Feb 23 10:11:33 2017 [Z0][ReM][D]: Req:832 UID:0 VirtualMachineDeploy result SUCCESS, 38
Thu Feb 23 10:11:35 2017 [Z0][ReM][D]: Req:5312 UID:0 VirtualMachineInfo invoked , 38
Thu Feb 23 10:12:34 2017 [Z0][TM][D]: Message received: TRANSFER SUCCESS 38 -
Thu Feb 23 10:16:52 2017 [Z0][ReM][D]: Req:8256 UID:0 VirtualMachineInfo invoked , 38
Whereas, for VM 39, selected by OpenNebula to run on a differen host, this gives:
root@one-1:~# grep " 39" /var/log/one/oned.log | grep "Thu Feb 23 10:" | more
Thu Feb 23 10:12:45 2017 [Z0][ReM][D]: Req:7568 UID:0 TemplateInstantiate result SUCCESS, 39
Thu Feb 23 10:13:34 2017 [Z0][ReM][D]: Req:832 UID:0 VirtualMachineDeploy invoked , 39, 1, false, 102
Thu Feb 23 10:13:34 2017 [Z0][DiM][D]: Deploying VM 39
Thu Feb 23 10:13:34 2017 [Z0][ReM][D]: Req:832 UID:0 VirtualMachineDeploy result SUCCESS, 39
Thu Feb 23 10:13:39 2017 [Z0][ReM][D]: Req:4832 UID:0 VirtualMachineInfo invoked , 39
Thu Feb 23 10:15:37 2017 [Z0][TM][D]: Message received: TRANSFER SUCCESS 39 -
Thu Feb 23 10:15:43 2017 [Z0][VMM][D]: Message received: LOG I 39 Successfully execute transfer manager driver operation: tm_c
ontext.
Thu Feb 23 10:15:44 2017 [Z0][VMM][D]: Message received: LOG I 39 ExitCode: 0
Thu Feb 23 10:15:44 2017 [Z0][VMM][D]: Message received: LOG I 39 Successfully execute network driver operation: pre.
Thu Feb 23 10:15:45 2017 [Z0][VMM][D]: Message received: LOG I 39 ExitCode: 0
Thu Feb 23 10:15:45 2017 [Z0][VMM][D]: Message received: LOG I 39 Successfully execute virtualization driver operation: deploy.
Thu Feb 23 10:15:45 2017 [Z0][VMM][D]: Message received: LOG I 39 Successfully execute network driver operation: post.
Thu Feb 23 10:15:45 2017 [Z0][VMM][D]: Message received: DEPLOY SUCCESS 39 one-39
Thu Feb 23 10:16:21 2017 [Z0][ReM][D]: Req:7328 UID:1 VirtualMachineInfo invoked , 39
Thu Feb 23 10:16:22 2017 [Z0][ReM][D]: Req:5968 UID:0 VirtualMachineUpdateTemplate invoked , 39, "READY=YES", 1
Thu Feb 23 10:16:22 2017 [Z0][ReM][D]: Req:5968 UID:0 VirtualMachineUpdateTemplate result SUCCESS, 39
Thu Feb 23 10:16:25 2017 [Z0][VMM][D]: VM 39 successfully monitored: DISK_SIZE=[ID=0,SIZE=2996] DISK_SIZE=[ID=1,SIZE=1] STATE
=a CPU=107.94 MEMORY=1048576 NETRX=2722478 NETTX=37526
On the thu* host, only the VM’s disk image is showing up, whereas the other hosts have additional files:
root@thu*:~# ls -la /var/lib/one/datastores/102/36
total 3066316
drwxrwxr-x 2 oneadmin oneadmin 4096 Feb 23 10:09 .
drwxr-xr-x 8 oneadmin oneadmin 4096 Feb 23 10:16 ..
-rw-r--r-- 1 oneadmin oneadmin 3139895296 Feb 23 10:10 disk.0
root@con*:~# ls -la /var/lib/one/datastores/102/39
total 3574464
drwxrwxr-x 2 oneadmin oneadmin 4096 Feb 23 10:15 .
drwxr-xr-x 6 oneadmin oneadmin 4096 Feb 23 10:13 ..
-rw-rw-r-- 1 oneadmin oneadmin 1218 Feb 23 10:15 deployment.0
-rw-r--r-- 1 libvirt-qemu kvm 3659857920 Feb 23 14:38 disk.0
-rw-r--r-- 1 libvirt-qemu kvm 374784 Feb 23 10:15 disk.1
Any hints on where to look would be apprciated.
