How correctly get variables from Template in hook?
Hello.
How can get variables from a xml template in a hook?
I have the hook:
ARGUMENTS = "$TEMPLATE"
ARGUMENTS_STDIN = yes
COMMAND   = "test/test.sh"
NAME      = "test"
ON        = "CUSTOM"
STATE     = "ACTIVE"
LCM_STATE = "RUNNING"
REMOTE    = "no"
RESOURCE  = VM
TYPE      = state
And i need get ETH0_IP and NAME from xml.
How correctly do it?
Hello.
I personally did like in the examples provided in sources, for example, from the autostart hook:
raw_vm_template = Base64.decode64(ARGV[0])
xml_vm_template = Nokogiri::XML(raw_vm_template)
VM_ID = xml_vm_template.xpath('VM/ID').text
So, you only need to know the XPATH you need /VM/NAME and /VM/TEMPLATE/CONTEXT/ETH0_IP in your case, this should do the job:
VM_NAME = xml_vm_template.xpath('/VM/NAME').text
VM_ETH0_IP = xml_vm_template.xpath('/VM/TEMPLATE/CONTEXT/ETH0_IP').text
Regards.
Hello.
Thank you for reply.
Can i use the same, but in shell, without ruby?
For shell usage, you should look at how it’s done in some MAD like the kvm MAD scripts.
I’ve created the hook:
ARGUMENTS_STDIN = "yes"
COMMAND         = "test.sh"
NAME            = "test"
ON              = "CUSTOM"
STATE           = "ACTIVE"
REMOTE          = "no"
RESOURCE        = "VM"
TYPE            = "state"
And the test.sh script:
#!/bin/bash
XPATH="/var/lib/one/remotes/datastore/xpath.rb --stdin"
TEMPLATE="$1"
unset i j XPATH_ELEMENTS
while IFS= read -r -d '' element; do
    XPATH_ELEMENTS[i++]="$element"
done < <($XPATH -b $TEMPLATE '/VM/ID')
VM_ID="${XPATH_ELEMENTS[j++]}"
echo "$VM_ID" > /tmp/test.txt
Hook runs correctly, but the file /tmp/test.txt is empty.
Did you check that $1 got the template, I think it should be base64 -d before being used or something like that.
Try:
#!/bin/bash
TEMPLATE="$1"
echo "$TEMPLATE" > /tmp/template-test.txt
I’ve added this lines to my script:
TEMPLATE=`base64 -d $1`
And the file /tmp/template-test.txt contains a full template)
But the script doesn’t work correctly and i get the error:
base64: invalid input
/var/lib/one/remotes/datastore/xpath.rb:70:in `block in <main>': undefined method `elements' for nil:NilClass (NoMethodError)
        from /var/lib/one/remotes/datastore/xpath.rb:64:in `each'
        from /var/lib/one/remotes/datastore/xpath.rb:64:in `<main>'
Ok, just to be sure:
# Be sure input is base64 encoded
echo "$1" > /tmp/first-arg.txt
# First argument is a filename, so read standard input
TEMPLATE=$(echo -n $1 | base64 -d)
The file /tmp/first-arg.txt is empty.
And the file /tmp/template-test.txt empty too.((
You configured your hook with ARGUMENTS_STDIN = "yes", so “$1” is not defined, in this case you must read the data from STDIN
How read data from STDIN in my case?
I think the mistake can be in this construction:
TEMPLATE="base64 -d $1"
For example, you could take a look at how to handle the stdin from vmm/kvm/restore script one/restore at master · OpenNebula/one · GitHub
In your case, if the stdin stream is base64 encoded, you need to just read it with cat and use xpath.rb to do the decode to raw XML the following sample should work
TEMPLATE="$(cat)"
Hope this helps.
Best Regards,
Works fine.
Thank you so much
Thanks For this solution Its really helped me alot I was facing since many days
Hello @atodorov_storpool @ahuertas @amarti
I am facing some issues with API Hook for VM actions.
Can we create hook on adding actions to VM? like I want to run script as soon as I have added action on VM such as poweroff or terminate.
I am using below hook tmpl but not working.
NAME = hook-API
TYPE = api
COMMAND = “log_new_action.rb”
ARGUMENTS = $API
CALL = “one.user.action”
Could you please suggest if possible.
Thanks!
Thanks For this solution..
