saint
(saint_)
July 1, 2019, 8:41pm
1
So here is my issue.
internet <- AudioCodes SBC -> OpenNebula 5.8.2 <-> Nodes
A the beginning, everything worked correctly.
Then we decided to use SSL connections.
So the SBC now forward port 443 to NGINX@OpenNebula:443
We can connect. The only issue is with the VNC no coming up.
root@boson:/etc> more nginx/conf.d/default.conf
#### OpenNebula Sunstone Upstream
upstream sunstone {
server 127.0.0.1:9869;
server {
listen 443 ssl;
server_name xyz.com;
### SSL Parameters
#ssl on;
ssl_certificate /etc/ssl/certs/nginx-selfsigned.crt;
ssl_certificate_key /etc/ssl/private/nginx-selfsigned.key;
### Proxy requests to upstream
location / {
proxy_pass http://sunstone;
And my sunstone-server vnc configuration:
:vnc_proxy_port: 29876
:vnc_proxy_support_wss: no
:vnc_proxy_cert:
:vnc_proxy_key:
:vnc_proxy_ipv6: false
:vnc_request_password: false
Is there anything else to do ?
I can connect to the Sunstone GUI, but if I request a VNC, all I get is this:
##### VNC noVNC ready: native WebSockets, canvas rendering
ahuertas
(Alejandro Huertas)
July 2, 2019, 10:00am
2
Hello @saint
To use VNC with SSL, you need to add the following:
:vnc_proxy_support_wss: only
:vnc_proxy_cert: /etc/one/ssl/opennebula-certchain.pem
:vnc_proxy_key: /etc/one/ssl/opennebula-key.pem
saint
(saint_)
July 2, 2019, 3:00pm
3
Greetings Alejandro,
I tried this without success (restarting sunstone and nginx)… Any other idea by any chance ?
saint
(saint_)
July 2, 2019, 5:10pm
5
When I try to launch the VNC,
VNC Server disconnected (code: 1006)
saint
(saint_)
July 2, 2019, 5:27pm
6
Here is the new config I tried:
upstream sunstone {
upstream websocketproxy {
server 127.0.0.1:29876;
#### my.machine.com HTTPS host
server {
listen 443 ssl;
server_name machine.com;
### SSL Parameters
#ssl on;
ssl_dhparam /etc/ssl/certs/dhparam.pem;
location / {
proxy_redirect off;
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-FOR $proxy_add_x_forwarded_for;
location /websockify {
proxy_pass http://websocketproxy;
proxy_http_version 1.1;
add_header Access-Control-Allow-Origin *;
And in the sunstone-server:
:vnc_proxy_cert: /etc/ssl/certs/nginx-selfsigned.crt
:vnc_proxy_key: /etc/ssl/private/nginx-selfsigned.key
I made sure the .crt, .key, and .pem belong to oneadmin:oneadmin
I restarted opennebula-sunstone, opennebubla-novnc, and Nginx
Still without success. Same error message as above.
ahuertas
(Alejandro Huertas)
July 3, 2019, 6:59am
7
What error do you see in /var/log/one/novnc.log?
You have configured ssl only for the websockets so you should try
proxy_pass https://websocketproxy;
If I am not wrong it will work in a slightly weird way - it will show 1006 but if you click to open in separate window it will work. The final solution I came to is as follow - in nginx I am using ssl cert from letsencrypt and a self-signed certificate for the websocketsproxy. There is a separate port on nginx for websocketproxy 89:
# OpenNebula Sunstone upstream
upstream sunstone {
# No squealing.
server_tokens off;
# To upload ISO files, increase for VMs images
client_max_body_size 4G;
server {
server_name public.host.com; # managed by Certbot
root /usr/share/nginx/html;
location / {
proxy_redirect off;
log_not_found off;
# VNC connection timeout
proxy_read_timeout 61s;
# Disable cache
proxy_buffering off;
error_page 404 /404.html;
location = /40x.html {
error_page 500 502 503 504 /50x.html;
location = /50x.html {
listen [::]:443 ssl ipv6only=on; # managed by Certbot
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/public.host.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/public.host.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
listen 89 ssl;
listen [::]:89 ssl;
location / {
# Disable cache
The sunstone-server.conf is as follow:
:vnc_proxy_port: 127.0.0.1:29876
:vnc_proxy_support_wss: yes
:vnc_proxy_cert: /etc/pki/tls/certs/websockify.crt
:vnc_proxy_key: /etc/pki/tls/certs/websockify.key
:vnc_client_port: 89
Not perfect but works for me …
Hope this helps
edit: just noticed that there are some configuration artifacts for websocket without ssl…
Best Regards,
saint
(saint_)
July 3, 2019, 1:00pm
9
Hey Anton,
I tried what you recommended, and still not working.
I will share my new configuration in a little while.
Thank you for the help!
saint
(saint_)
July 8, 2019, 6:55pm
10
In the novice.log, all I have now is
handler exception: [Errno 13] Permission denied
saint
(saint_)
July 9, 2019, 3:12pm
11
I changed that with changing the rights to the private cert, but still get the VNC Diconnected: code 1006 now
You should try oeningn the dev console in the browser and look the logged errors. Usualy there are hints from the browser what is not working (connection refused, cert not valid, etc…)
saint
(saint_)
July 10, 2019, 1:44pm
13
Would you have a link ?
Because beside my basic dev console I did not find anything I could add-on regarding nginx…
saint
(saint_)
July 11, 2019, 7:26pm
14
Issue resolved by redesigning part of our network.
I wish we did not have to, but could not wait for this to be fixed.
thanks
