I am running a 2 nodes cluster + the sunstone, and the main purpose of this infrastructure was to migrate all the VM’s that we have in Xen servers to this cloud, so what I did it was to convert the xen images to qcow2, which are able to run over the KVM hosts. Once I’ve got this VM running (I can access to it from virt-manager that I have installed on the cluster), I try to import it following the instructions from Opennebula but it throws the following error:
Tue Jul 5 10:34:39 2016 [Z0][ReM][E]: Req:9536 UID:0 VirtualMachineAllocate result FAILURE [VirtualMachineAllocate] Error allocating a new virtual machine. Parse error: syntax error, unexpected CBRACKET, expecting VARIABLE at line 12, columns 143:147
More over, I’ve tried different approaches to try to migrate my current infrastructure to the cloud, but it didn’t work out . For example I’ve tried replacing the disk image with a VM that is already defined in the cloud, or creating an image and attaching this to an existing VM, or even creating a template based on that image (qcow2 file)
Not sure if this might be related, but the image contains /dev/vda1 and /dev/mapper/VolGroup_root
being vda1 /boot and the VG the rest of the filesystem
a
