Impossible to set IP address when onetemplate instantiate
Hello!
I keep getting “Cannot get IP/MAC lease from virtual network” trying to run:
onetemplate instantiate 69 --hold
–name testvm --memory 2048
–cpu 4 --vcpu 4
–user-inputs “SET_HOSTNAME=test”,“CORES_PER_SOCKET=2”,“IPADDR”=“10.50.28.100”
but it gets ip address OK when I set the var directly like that:
NIC = [
IP = “10.50.28.100”,
I think the possible reason may be that no IP variable substitution happens when
IP = $IPADDR
(am I right here?)
Extracts from the template:
CONTEXT = [
CORES_PER_SOCKET = “$CORES_PER_SOCKET”,
IPADDR = “$IPADDR”,
SET_HOSTNAME = “$SET_HOSTNAME”,
NETWORK = “YES”,
NIC = [
IP = “$IPADDR”,
NETWORK = “WN_int_10-50-28-15”,
NETWORK_UNAME = “gridadmin”,
SECURITY_GROUPS = “0” ]
USER_INPUTS = [
CORES_PER_SOCKET = “M|number|cores per socket| |”,
IPADDR = “M|text|ipaddress| |”,
SET_HOSTNAME = “M|text|VM hostname| |” ]
Notes:
Other variables SET_HOSTNAME and CORES_PER_SOCKET that is used in section
TOPOLOGY = [CORES = “$CORES_PER_SOCKET”, … ]
are initiated OK.
I tried disable/enable network contextualization
CONTEXT = [
NETWORK = “YES”,
with no luck.
My OpenNebula version: 6.2.0.1
best regards,
Dzmitry
Instead of defining the IP parameter in the NIC, try and define ETH0_IP in the CONTEXT section.
For example
CONTEXT = [
ETH0_IP="$IPADDR",
NETWORK = “YES”,
NIC = [
USER_INPUTS = [
Daniel,
thank you very much for your reply.
Unfortunatly, it does not work. It looks like Opennebula ignores direct ETH0_IP setting.
As a result I can see that settings in the VM template:
User template
CORES_PER_SOCKET = “2”
IPADDR = “"10.50.28.100"”
USER_INPUTS = [
IPADDR = “M|text|ipaddress| |"10.50.28.100"”,
Template
CONTEXT = [
CORES_PER_SOCKET = “2”,
ETH0_IP = “10.50.28.100”,
NETWORK = “YES”,
SET_HOSTNAME = “test”]
NIC = [
IP = “10.50.28.15”,
NAME = “NIC0”,
NETWORK = “WN_int_10-50-28-15” ]
TOPOLOGY = [
CORES = “$CORES_PER_SOCKET” ]
My 10.50.28.100 is ignored and 10.50.28.15 is autoselected from available Network address range.
p.s. and I found that “Add network contextualization” checkbock has no effect on the selection process.
Dzmitry
I think the problem could be that you have both NIC[IP] and CONTEXT[ETH0_IP]. Try removing NIC[IP] and just leave ETH0_IP in CONTEXT.
Daniel,
thank you!
The problem was that I set no NIC[IP] when instantiated that VM. That value 10.50.28.15 was autoselected and desirable IP was ignored.
I posted the template of active and running VM, I can see it in menu “Instances” → “VM”.
I tried different combinations of settings. In the end I just used web fontend to start all my VMs. There was no problem to set desirable IP addresses for VMs by GUI - unlike CLI.
Dzmitry
