OpenNebula 4.12.1:
It seems that changing replication settings on a slave makes the datastore temporarily unavailable. This is all fine, but the error message given by ‘oneimage create’ is unclear: “Not enough space in datastore”. This creates an intermittent problem that is hard to debug. A message like “Datastore not available” or “Datastore not yet initialized” would be much better.
Create a federated OpenNebula with MySQL backend, and run the folowing ansible tasks on the slave:
- name: stop slave
mysql_replication: login_user=root login_password='{{rootpass}}' mode=stopslave
# THIS TASK SEEMS TO BE CREATING A DATASTORE TIMING ISSUE
- name: set replication master
mysql_replication: login_user=root login_password='{{rootpass}}' mode=changemaster master_host={{opennebula.sunstone_master_ip}} master_user='one-slave' master_password='{{opennebula.mysql_oneslave_pass}}'
ignore_errors: True # FIXME, mysql_replication gives a warning (although things do work)
- name: start slave
mysql_replication: login_user=root login_password='{{rootpass}}' mode=startslave
tags: replication-restart
- name: restart opennebula-sunstone after adding replication settings
service: name={{item}} state=restarted
with_items:
- opennebula-sunstone
- opennebula
- name: create image
shell: oneimage list | grep -q Ubuntu || oneimage create --name "Ubuntu" --path ~oneadmin/ubuntu-14.04-amd64.img --driver qcow2 --datastore default
sudo_user: oneadmin
The following command will eventually succeed:
# while ! oneimage list | grep Ubuntu ; do oneimage create --name Ubuntu --path ubuntu-14.04-amd64.img --driver qcow2 --datastore default; done; oneimage list
0 oneadmin oneadmin Ubuntu default 2.2G OS No lock 0
ID USER GROUP NAME DATASTORE SIZE TYPE PER STAT RVMS
If you remove the task marked above with “TIMING ISSUE”, things will work immediately.
It would be great if oneimage (and similar tools) would give a clearer error if there is things are getting initialized or are otherwise unavailable, as this error makes it fairly hard to debug.
