Issues types and priority determination
Can someone tell me what is the difference between the different issue types in the “dev.opennebula.org” website? i mean what is the difference between bugs, features, tasks, requests, backlogs, and back ports?
Moreover, How the priority of a suggested issue is determined?
Thanks in advance.
Hazar Y.
They are described in the description about how to contribute new code to OpenNebula at http://opennebula.org/community/contribute/
Regards,
Thanks a lot for the clarification. However, there is no description about “Task” and " Back port" issue types. Can you clarify these two types for me?
Thanks
Hazar Y.
Hi Hazar Y,
They are actually not used and have been removed. Thanks!
Thanks a lot :smile:
