After shutdown my old VM with sda disks it couldn’t start, and I have got an error:
"Fri Feb 2 13:17:56 2018 [Z0][VMM][I]: error: конфигурация не поддерживается: значение «target» для контроллера модели lsilogic должно быть равно 0"
My translate this log string:
error :Configuration is not supported: target value for lsilogic controller must be 0
I have red deployment file:
<devices>
<emulator><![CDATA[/usr/bin/qemu-system-x86_64]]></emulator>
<disk type='file' device='disk'>
<source file='/var/lib/one//datastores/0/120/disk.0'/>
<target dev='sdb'/>
<boot order='1'/>
<driver name='qemu' type='raw' cache='none'/>
<address type='drive' controller='0' bus='0' target='1' unit='0'/>
</disk>
<source file='/var/lib/one//datastores/0/120/disk.2'/>
<target dev='sdc'/>
<driver name='qemu' type='qcow2' cache='none'/>
<address type='drive' controller='0' bus='0' target='2' unit='0'/>
</disk>
<source file='/var/lib/one//datastores/0/120/disk.3'/>
<target dev='sdd'/>
<address type='drive' controller='0' bus='0' target='3' unit='0'/>
</disk>
And changed attributes:
target to 0
unit to previous target value
<address type='drive' controller='0' bus='0' target='0' unit='2'/>
Next I executed: virsh -d 0 create deployment.13, and VM started without errors
Opennebula 5.4.1
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION=“Ubuntu 16.04.2 LTS”
