LDAP autentication error
Hello.
Just make clean install of 5.4 on centos 7. All seems ok but overcommitment and ldap authentication.
About ldap - i have done it by docs. After i create a user with ldap driver in Sunstone and tries to login i receive an errors in my oned.log
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 Command execution fail: /var/lib/one/remotes/auth/ldap/authenticate gorlov - ****
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: Command execution fail: /var/lib/one/remotes/auth/ldap/authenticate gorlov - ****
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 Trying server server 1
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: Trying server server 1
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 Exception raised authenticating to LDAP
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: Exception raised authenticating to LDAP
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 #<Encoding::CompatibilityError: incompatible encoding regexp match (UTF-8 regexp with ASCII-8BIT string)>
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: #<Encoding::CompatibilityError: incompatible encoding regexp match (UTF-8 regexp with ASCII-8BIT string)>
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:755:in `scan’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:755:in scan' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:755:inparse_filter_branch’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:755:in parse_filter_branch' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:737:inparse_paren_expression’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:737:in parse_paren_expression' Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:737:inparse_paren_expression’
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:682:in `parse’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:682:in parse' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:673:ininitialize’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:673:in initialize' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:667:innew’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:667:in new' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:667:inparse’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:667:in parse' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:341:inconstruct’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:341:in construct' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/connection.rb:322:insearch’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/connection.rb:322:in search' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:753:inblock (2 levels) in search’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:753:in block (2 levels) in search' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:1228:inuse_connection’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:1228:in use_connection' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:752:inblock in search’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:752:in block in search' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/instrumentation.rb:19:ininstrument’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/instrumentation.rb:19:in instrument' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:751:insearch’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:751:in search' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /usr/lib/one/ruby/opennebula/ldap_auth.rb:158:inis_in_group?’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/lib/one/ruby/opennebula/ldap_auth.rb:158:in is_in_group?' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /var/lib/one/remotes/auth/ldap/authenticate:79:inblock in ’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /var/lib/one/remotes/auth/ldap/authenticate:79:in block in <main>' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /var/lib/one/remotes/auth/ldap/authenticate:59:ineach’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /var/lib/one/remotes/auth/ldap/authenticate:59:in each' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 /var/lib/one/remotes/auth/ldap/authenticate:59:in’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /var/lib/one/remotes/auth/ldap/authenticate:59:in `'
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 Could not authenticate user gorlov
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: Could not authenticate user gorlov
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 2 ExitCode: 255
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: ExitCode: 255
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: AUTHENTICATE FAILURE 2 -
Thu Aug 17 18:42:14 2017 [Z0][AuM][E]: Auth Error:
Thu Aug 17 18:42:14 2017 [Z0][ReM][D]: Req:1280 UID:-1 one.user.info invoked , -1
Thu Aug 17 18:42:14 2017 [Z0][ReM][E]: Req:1280 UID:- one.user.info result FAILURE [one.user.info] User couldn’t be authenticated, aborting call.
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 Command execution fail: /var/lib/one/remotes/auth/ldap/authenticate gorlov - ****
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 Trying server server 1
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 Exception raised authenticating to LDAP
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 #<Encoding::CompatibilityError: incompatible encoding regexp match (UTF-8 regexp with ASCII-8BIT string)>
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:755:in `scan’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:755:in scan' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:755:inparse_filter_branch’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:755:in parse_filter_branch' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:737:inparse_paren_expression’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:737:in parse_paren_expression' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:682:inparse’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:682:in parse' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:673:ininitialize’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:673:in initialize' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:667:innew’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:667:in new' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:667:inparse’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:667:in parse' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:341:inconstruct’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/filter.rb:341:in construct' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/connection.rb:322:insearch’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/connection.rb:322:in search' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:753:inblock (2 levels) in search’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:753:in block (2 levels) in search' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:1228:inuse_connection’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:1228:in use_connection' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:752:inblock in search’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:752:in block in search' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/instrumentation.rb:19:ininstrument’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap/instrumentation.rb:19:in instrument' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:751:insearch’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/local/share/gems/gems/net-ldap-0.12.1/lib/net/ldap.rb:751:in search' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /usr/lib/one/ruby/opennebula/ldap_auth.rb:158:inis_in_group?’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /usr/lib/one/ruby/opennebula/ldap_auth.rb:158:in is_in_group?' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /var/lib/one/remotes/auth/ldap/authenticate:79:inblock in ’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /var/lib/one/remotes/auth/ldap/authenticate:79:in block in <main>' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /var/lib/one/remotes/auth/ldap/authenticate:59:ineach’
Thu Aug 17 18:42:14 2017 [Z0][AuM][I]: /var/lib/one/remotes/auth/ldap/authenticate:59:in each' Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 /var/lib/one/remotes/auth/ldap/authenticate:59:in’
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 Could not authenticate user gorlov
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: LOG I 3 ExitCode: 255
Thu Aug 17 18:42:14 2017 [Z0][AuM][D]: Message received: AUTHENTICATE FAILURE 3 -
Thu Aug 17 18:42:14 2017 [Z0][ReM][D]: Req:2000 UID:-1 one.user.info invoked , -1
Thu Aug 17 18:42:14 2017 [Z0][ReM][E]: Req:2000 UID:- one.user.info result FAILURE [one.user.info] User couldn’t be authenticated, aborting call.
Thu Aug 17 18:42:23 2017 [Z0][ReM][D]: Req:6160 UID:0 one.zone.raftstatus invoked
Thu Aug 17 18:42:23 2017 [Z0][ReM][D]: Req:6160 UID:0 one.zone.raftstatus result SUCCESS, "<SERVER_ID>-1<…"
Thu Aug 17 18:42:23 2017 [Z0][ReM][D]: Req:352 UID:0 one.vmpool.info invoked , -2, -1, -1, -1
