systemctl status libvirtd
libvirtd[17079]: unsupported configuration: Security driver apparmor not enabled
all work fine but i dont know if i should care about this
what distro are you using? have you modified anything in under /etc/apparmor.d/ ? It should work by default
ubuntu 16.04 and apparmor fresh install i make apt purge than apt install apparmor
