After starting VM using username : root .but when i brows the localhost it shows localhost is unavailable.
where is the problem,i cann’t understand.help me please.
Can you elaborate more on your issue. Do you browse within the VM or from your computer? Why not you browse using the VM’s IP address.
yes ,i use VM IP address 127.0.0.1 . but it replay it is unavailable
Is your loopback interface up?
Kind Regards,
