I’ve been tried to configure LVM datastorage in testing environment consists of two hosts:
- nebula (front machine) with Sunstone
- kvm-node-1 host with configured VG
nebula machine contains following:
root@nebula:/var/lib/one/datastores# onedatastore list
0 system - - 0 0 sys - ssh on
1 default 39.1G 70% 0 4 img fs ssh on
2 files 39.1G 70% 0 0 fil fs ssh on
100 images_shared 39.1G 70% 0 2 img fs shared on
104 lvm_system 39.1G 76% 0 0 sys - fs_lvm on
105 lvm_images 39.1G 70% 0 1 img fs fs_lvm on
106 lvm_system2 39.1G 76% 0 0 sys - fs_lvm on
root@nebula:/var/lib/one/datastores# ls /var/lib/one/datastores/
0 1 100 101 105 2
root@nebula:/var/lib/one/datastores# showmount -e
Export list for nebula:
/var/lib/one/datastores/105 192.168.122.0/24
/var/lib/one/datastores/100 192.168.122.0/24
kvm-node-1 machine contains following:
root@kvm-node-1:/var/lib/one/datastores# ls /var/lib/one/datastores/
0 100 104 105 106
root@kvm-node-1:/var/lib/one/datastores# mount|grep nfs
nfsd on /proc/fs/nfsd type nfsd (rw,relatime)
192.168.122.240:/var/lib/one/datastores/100 on /var/lib/one/datastores/100 type nfs4 (rw,relatime,vers=4.2,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.122.74,local_lock=none,addr=192.168.122.240)
192.168.122.240:/var/lib/one/datastores/105 on /var/lib/one/datastores/105 type nfs4 (rw,relatime,vers=4.2,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.122.74,local_lock=none,addr=192.168.122.240)
root@kvm-node-1:/var/lib/one/datastores# vgs
VG #PV #LV #SN Attr VSize VFree
vg-one-0 1 1 0 wz--n- <10,00g <9,98g
I can deploy VM with image to the hypervisor via Sunstone. This image is successfully start. But I can’t terminate VM due to errors:
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 Command execution failed (exit code: 5): /var/lib/one/remotes/tm/fs_lvm/delete nebula:/var/lib/one//datastores/0/29/disk.0 29 105
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG E 29 delete: Command " set -x
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 DEV=$(readlink /var/lib/one/datastores/0/29/disk.0)
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 if [ -d "/var/lib/one/datastores/0/29/disk.0" ]; then
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 rm -rf "/var/lib/one/datastores/0/29/disk.0"
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 else
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 rm -f /var/lib/one/datastores/0/29/disk.0
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 if [ -z "$DEV" ]; then
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 exit 0
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 fi
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 if echo "$DEV" | grep "^/dev/" &>/dev/null; then
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 sudo lvremove -f $DEV
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 fi" failed: ++ readlink /var/lib/one/datastores/0/29/disk.0
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 + DEV=/dev/vg-one-0/lv-one-29-0
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 + '[' -d /var/lib/one/datastores/0/29/disk.0 ']'
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 + rm -f /var/lib/one/datastores/0/29/disk.0
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 + '[' -z /dev/vg-one-0/lv-one-29-0 ']'
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 + echo /dev/vg-one-0/lv-one-29-0
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 + grep '^/dev/'
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 + sudo lvremove -f /dev/vg-one-0/lv-one-29-0
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 Volume group "vg-one-0" not found
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG I 29 Cannot process volume group vg-one-0
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: LOG E 29 Error deleting /var/lib/one/datastores/0/29/disk.0
Fri Nov 9 16:04:55 2018 [Z0][TM][D]: Message received: TRANSFER FAILURE 29 Error deleting /var/lib/one/datastores/0/29/disk.0
How should I organise interchange between front machine and hypervisor machine with LVM datastorage to solve this issue?
Why nebula is trying to remove lv from own host?
