Lxc container giving error while launching
We have added lxc node and while creating lxc container using market places images its giving below error related to block devices not on such as below.
Thu Feb 13 13:49:48 2025 [Z0][VM][I]: New state is ACTIVE
Thu Feb 13 13:49:48 2025 [Z0][VM][I]: New LCM state is PROLOG
Thu Feb 13 13:51:12 2025 [Z0][VM][I]: New LCM state is BOOT
Thu Feb 13 13:51:12 2025 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/119/deployment.0
Thu Feb 13 13:51:14 2025 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Thu Feb 13 13:51:15 2025 [Z0][VMM][I]: ExitCode: 0
Thu Feb 13 13:51:15 2025 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Thu Feb 13 13:51:15 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/mkdir -p.
Thu Feb 13 13:51:15 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one//datastores/118/119/vm.xml.
Thu Feb 13 13:51:16 2025 [Z0][VMM][I]: ExitCode: 0
Thu Feb 13 13:51:16 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one//datastores/118/119/ds.xml.
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: Command execution fail (exit code: 255): cat << ‘EOT’ | /var/tmp/one/vmm/lxc/deploy ‘/var/lib/one//datastores/118/119/deployment.0’ ‘blrnode1’ 119 blrnode1
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: deploy: No block device on /var/lib/one/datastores/118/119/mapper/disk.0
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: deploy: No block device on /var/lib/one/datastores/118/119/mapper/disk.1
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: sudo lxc-ls
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: lsblk -o NAME,FSTYPE
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: sudo -n mount /dev/vg-one-118/lv-one-119-0 /var/lib/one/datastores/118/119/mapper/disk.0
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: sudo -n bindfs --uid-offset=-9869 --gid-offset=-9869 -o suid /var/lib/one/datastores/118/119/mapper/disk.0 /var/lib/lxc-one/119/disk.0
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: sudo -n losetup --find --show /var/lib/one/datastores/118/119/disk.1
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: sudo -n mount /dev/loop0 /var/lib/one/datastores/118/119/mapper/disk.1
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: sudo -n bindfs --uid-offset=-9869 --gid-offset=-9869 -o suid /var/lib/one/datastores/118/119/mapper/disk.1 /var/lib/lxc-one/119/disk.1
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: sudo lxc-create -n ‘one-119’ --config /var/lib/one/datastores/118/119/deployment.file --template none
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: Error executing: sudo lxc-start -n ‘one-119’
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: [stderr]: lxc-start: one-119: lxccontainer.c: wait_on_daemonized_start: 851 Received container state “ABORTING” instead of “RUNNING”
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: lxc-start: one-119: tools/lxc_start.c: main: 329 The container failed to start
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: lxc-start: one-119: tools/lxc_start.c: main: 332 To get more details, run the container in foreground mode
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: lxc-start: one-119: tools/lxc_start.c: main: 335 Additional information can be obtained by setting the --logfile and --logpriority options
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: Check container logs at /var/log/lxc/one-119.log
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: sudo -n umount /var/lib/lxc-one/119/disk.1
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: sudo -n umount /var/lib/one/datastores/118/119/mapper/disk.1
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: sudo -n losetup -d /dev/loop0
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: Error executing: sudo lxc-destroy -n ‘one-119’
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: [stderr]: lxc-destroy: one-119: utils.c: _recursive_rmdir: 162 Inappropriate ioctl for device - Failed to delete “/var/lib/lxc-one/119/disk.0”
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: lxc-destroy: one-119: storage/dir.c: dir_destroy: 133 Failed to delete “/var/lib/lxc-one/119/disk.0”
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: lxc-destroy: one-119: lxccontainer.c: container_destroy: 2984 Error destroying rootfs for one-119
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: lxc-destroy: one-119: tools/lxc_destroy.c: do_destroy: 129 Destroying one-119 failed
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: There was an error starting the containter.
Thu Feb 13 13:51:17 2025 [Z0][VMM][I]: ExitCode: 255
Thu Feb 13 13:51:18 2025 [Z0][VMM][I]: ExitCode: 0
Thu Feb 13 13:51:18 2025 [Z0][VMM][I]: Successfully execute network driver operation: clean.
Thu Feb 13 13:51:18 2025 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Thu Feb 13 13:51:18 2025 [Z0][VMM][E]: DEPLOY: INFO: deploy: No block device on /var/lib/one/datastores/118/119/mapper/disk.0 INFO: deploy: No block device on /var/lib/one/datastores/118/119/mapper/disk.1 sudo lxc-ls lsblk -o NAME,FSTYPE lsblk -o NAME,FSTYPE lsblk -o NAME,FSTYPE lsblk -o NAME,FSTYPE sudo -n mount /dev/vg-one-118/lv-one-119-0 /var/lib/one/datastores/118/119/mapper/disk.0 sudo -n bindfs --uid-offset=-9869 --gid-offset=-9869 -o suid /var/lib/one/datastores/118/119/mapper/disk.0 /var/lib/lxc-one/119/disk.0 sudo -n losetup --find --show /var/lib/one/datastores/118/119/disk.1 lsblk -o NAME,FSTYPE sudo -n mount /dev/loop0 /var/lib/one/datastores/118/119/mapper/disk.1 sudo -n bindfs --uid-offset=-9869 --gid-offset=-9869 -o suid /var/lib/one/datastores/118/119/mapper/disk.1 /var/lib/lxc-one/119/disk.1 sudo lxc-create -n ‘one-119’ --config /var/lib/one/datastores/118/119/deployment.file --template none Error executing: sudo lxc-start -n ‘one-119’ [stderr]: lxc-start: one-119: lxccontainer.c: wait_on_daemonized_start: 851 Received container state “ABORTING” instead of “RUNNING” lxc-start: one-119: tools/lxc_start.c: main: 329 The container failed to start lxc-start: one-119: tools/lxc_start.c: main: 332 To get more details, run the container in foreground mode lxc-start: one-119: tools/lxc_start.c: main: 335 Additional information can be obtained by setting the --logfile and --logpriority options Check container logs at /var/log/lxc/one-119.log INFO: deploy: No block device on /var/lib/one/datastores/118/119/mapper/disk.0 sudo -n umount /var/lib/lxc-one/119/disk.1 sudo -n umount /var/lib/one/datastores/118/119/mapper/disk.1 sudo -n losetup -d /dev/loop0 sudo lxc-ls Error executing: sudo lxc-destroy -n ‘one-119’ [stderr]: lxc-destroy: one-119: utils.c: _recursive_rmdir: 162 Inappropriate ioctl for device - Failed to delete “/var/lib/lxc-one/119/disk.0” lxc-destroy: one-119: storage/dir.c: dir_destroy: 133 Failed to delete “/var/lib/lxc-one/119/disk.0” lxc-destroy: one-119: lxccontainer.c: container_destroy: 2984 Error destroying rootfs for one-119 lxc-destroy: one-119: tools/lxc_destroy.c: do_destroy: 129 Destroying one-119 failed Check container logs at /var/log/lxc/one-119.log There was an error starting the containter. ExitCode: 255
Thu Feb 13 13:51:18 2025 [Z0][VM][I]: New LCM state is BOOT_FAILURE
lxc failed to start the container for whatever reason
Take a look at that file for clues
Hi Daniel,
Thanks for responding & sharing the clue to look the problem where lies but it will appreciate if you give some more information for below errors, which i found at suggested log location.
lxc-start one-124 20250213171408.829 ERROR conf - conf.c:mount_autodev:1133 - Input/output error - Failed to create “/dev” directory
lxc-start one-124 20250213171408.829 ERROR conf - conf.c:lxc_setup:3527 - Failed to mount “/dev”
lxc-start one-124 20250213171408.829 ERROR start - start.c:do_start:1299 - Failed to setup container “one-124”
lxc-start one-124 20250213171408.830 ERROR sync - sync.c:__sync_wait:62 - An error occurred in another process (expected sequence number 5)
lxc-start one-124 20250213171408.830 ERROR start - start.c:lxc_abort:1103 - Function not implemented - Failed to send SIGKILL to 21067
lxc-start one-124 20250213171408.830 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:851 - Received container state “ABORTING” instead of “RUNNING”
lxc-start one-124 20250213171408.832 ERROR start - start.c:__lxc_start:2019 - Failed to spawn container “one-124”
Perhaps there is an issue with the VM image. Please inspect the image contents and check if the filesystem in looks alright. For this you can
  • mount the logical volume sudo -n mount /dev/vg-one-118/lv-one-119-0 /var/lib/one/datastores/118/119/mapper/disk.0
  • then inspect the filesystem on the mountpoint ls -l /var/lib/one/datastores/118/119/mapper/disk.0.
If possible, please also share the VM instance template onevm show -j <vm_id>.
Thanks for your suggestion, Daniel. let me check this again will post you the further asked details.
Hi Daniel,
Pls find the asked details.
**************after mounting the said disk.0
[oneadmin@lxcnode mnt]$ ls -l
total 28
drwxr-xr-x 2 root root 4096 Feb 21 16:25 context
drw-r–r-- 2 root root 4096 Feb 21 16:20 dev
drwx------ 2 root root 16384 Feb 21 16:11 lost+found
drwxr-xr-x 2 root root 4096 Feb 21 16:25 proc
onevm show -j ****
[oneadmin@vOne opt]$ onevm show -j 166
“VM”: {
"ID": "166",
"UID": "0",
"GID": "0",
"UNAME": "oneadmin",
"GNAME": "oneadmin",
"NAME": "cn",
"PERMISSIONS": {
  "OWNER_U": "1",
  "OWNER_M": "1",
  "OWNER_A": "0",
  "GROUP_U": "0",
  "GROUP_M": "0",
  "GROUP_A": "0",
  "OTHER_U": "0",
  "OTHER_M": "0",
  "OTHER_A": "0"
"LAST_POLL": "1740388944",
"STATE": "3",
"LCM_STATE": "36",
"PREV_STATE": "3",
"PREV_LCM_STATE": "36",
"RESCHED": "0",
"STIME": "1740388091",
"ETIME": "0",
"DEPLOY_ID": {
"MONITORING": {
  "DISK_SIZE": [
      "ID": "0",
      "SIZE": "3"
      "ID": "1",
      "SIZE": "1"
  "ID": "166",
  "TIMESTAMP": "1740388944"
"SCHED_ACTIONS": {
"TEMPLATE": {
  "AUTOMATIC_DS_REQUIREMENTS": "(\"CLUSTERS/ID\" @> 103)",
  "AUTOMATIC_NIC_REQUIREMENTS": "(\"CLUSTERS/ID\" @> 103)",
  "AUTOMATIC_REQUIREMENTS": "(CLUSTER_ID = 103) & !(PUBLIC_CLOUD = YES) & !(PIN_POLICY = PINNED)",
  "CONTEXT": {
    "DISK_ID": "1",
    "NETWORK": "YES",
    "SET_HOSTNAME": "cn",
    "SSH_PUBLIC_KEY": "ssh-rsa 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 oneadmin@vOne\nssh-rsa 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 root@vOne",
    "TARGET": "hda"
  "CPU": "1",
  "DISK": [
      "ALLOW_ORPHANS": "YES",
      "CLONE": "YES",
      "CLONE_TARGET": "SYSTEM",
      "CLUSTER_ID": "103",
      "DATASTORE": "raw_device_ds",
      "DATASTORE_ID": "130",
      "DEV_PREFIX": "sd",
      "DISK_ID": "0",
      "DISK_SNAPSHOT_TOTAL_SIZE": "0",
      "DISK_TYPE": "BLOCK",
      "DRIVER": "raw",
      "FORMAT": "raw",
      "IMAGE": "oracle_7 - LXC",
      "IMAGE_ID": "83",
      "IMAGE_STATE": "2",
      "LN_TARGET": "SYSTEM",
      "ORIGINAL_SIZE": "2048",
      "READONLY": "NO",
      "SAVE": "NO",
      "SIZE": "10240",
      "SOURCE": "/var/lib/one//datastores/130/35da8374e10d46822bb293697d204eff",
      "TARGET": "sda",
      "TM_MAD": "ssh",
      "TYPE": "BLOCK"
  "GRAPHICS": {
    "LISTEN": "0.0.0.0",
    "PORT": "6066",
    "TYPE": "vnc"
  "MEMORY": "768",
  "OS": {
    "UUID": "6cad0d83-7c03-4dd3-8cb7-19721d310a5c"
  "TEMPLATE_ID": "64",
  "TM_MAD_SYSTEM": "ssh",
  "VCPU": "2",
  "VMID": "166"
"USER_TEMPLATE": {
  "LXC_UNPRIVILEGED": "false",
  "SCHED_DS_REQUIREMENTS": "ID=\"125\"",
  "SCHED_REQUIREMENTS": "ID=\"8\""
"HISTORY_RECORDS": {
  "HISTORY": {
    "OID": "166",
    "SEQ": "0",
    "HOSTNAME": "lxcnode",
    "HID": "8",
    "CID": "103",
    "STIME": "1740388099",
    "ETIME": "0",
    "VM_MAD": "lxc",
    "TM_MAD": "ssh",
    "DS_ID": "125",
    "PSTIME": "1740388099",
    "PETIME": "1740388104",
    "RSTIME": "1740388104",
    "RETIME": "1740388109",
    "ESTIME": "0",
    "EETIME": "0",
    "ACTION": "0",
    "UID": "-1",
    "GID": "-1",
    "REQUEST_ID": "-1"
"BACKUPS": {
  "BACKUP_CONFIG": {
  "BACKUP_IDS": {
This looks like an empty container image. There is no Linux FS to run.
What OS/distro do you have on the LXC node and what marketplace appliance did you use to create the container ?
