As I attempt to instantiate LXD container it fails to boot with an error stating
Failed to execute network driver operation: post.
Perhaps some ubuntu update killed it as it was working before but nothing drastically change on ubuntu 18.04 boxes I run
Here is the github issue:
Here is the log just in case:
Here is the full LXD log:
Fri Aug 16 11:45:11 2019 [Z0][VM][I]: New state is ACTIVE
Fri Aug 16 11:45:11 2019 [Z0][VM][I]: New LCM state is PROLOG
Fri Aug 16 11:45:13 2019 [Z0][VM][I]: New LCM state is BOOT
Fri Aug 16 11:45:13 2019 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/76/deployment.0
Fri Aug 16 11:45:13 2019 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Fri Aug 16 11:45:14 2019 [Z0][VMM][I]: ExitCode: 0
Fri Aug 16 11:45:14 2019 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: deploy: Processing disk 0
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: deploy: Using rbd disk mapper for
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: deploy: Mapping disk at /var/snap/lxd/common/lxd/storage-pools/default/containers/one-76/rootfs using device /dev/nbd1
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: deploy: Resizing filesystem ext4 on /dev/nbd1
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: deploy: Mounting /dev/nbd1 at /var/snap/lxd/common/lxd/storage-pools/default/containers/one-76/rootfs
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: deploy: Mapping disk at /var/lib/one/datastores/101/76/mapper/disk.1 using device /dev/loop0
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: deploy: Mounting /dev/loop0 at /var/lib/one/datastores/101/76/mapper/disk.1
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: deploy: — Starting container —
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: ExitCode: 0
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: Successfully execute virtualization driver operation: deploy.
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: Command execution fail: /var/tmp/one/vnm/fw/post 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 ‘one-76’
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: iptables v1.6.1: interface name --physdev-is-bridged' must be shorter than IFNAMSIZ (15) Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: Try iptables -h’ or ‘iptables --help’ for more information.
Fri Aug 16 11:45:16 2019 [Z0][VMM][E]: post: Command Error: sudo iptables -I opennebula -m physdev --physdev-out --physdev-is-bridged -j one-76-0-i
Fri Aug 16 11:45:16 2019 [Z0][VMM][E]: post: [“/var/tmp/one/vnm/command.rb:62:in block in run!'", "/var/tmp/one/vnm/command.rb:59:in each’”, “/var/tmp/one/vnm/command.rb:59:in run!'", "/var/tmp/one/vnm/security_groups_iptables.rb:485:in nic_pre’”, “/var/tmp/one/vnm/sg_driver.rb:92:in block in activate'", "/var/tmp/one/vnm/vnm_driver.rb:79:in block in process’”, “/var/tmp/one/vnm/vm.rb:64:in block in each_nic'", "/var/tmp/one/vnm/vm.rb:63:in each’”, “/var/tmp/one/vnm/vm.rb:63:in each_nic'", "/var/tmp/one/vnm/vnm_driver.rb:82:in process’”, "/var/tmp/one/vnm/sg_driver.rb:84:in activate'", "/var/tmp/one/vnm/fw/post:32:in
Fri Aug 16 11:45:16 2019 [Z0][VMM][I]: ExitCode: 1
Fri Aug 16 11:45:17 2019 [Z0][VMM][I]: shutdown: — Stopping container —
Fri Aug 16 11:45:17 2019 [Z0][VMM][I]: shutdown: Processing disk 0
Fri Aug 16 11:45:17 2019 [Z0][VMM][I]: shutdown: Using rbd disk mapper for
Fri Aug 16 11:45:17 2019 [Z0][VMM][I]: shutdown: Unmapping disk at /var/snap/lxd/common/lxd/storage-pools/default/containers/one-76/rootfs
Fri Aug 16 11:45:17 2019 [Z0][VMM][I]: shutdown: Umounting disk mapped at /dev/nbd1
Fri Aug 16 11:45:17 2019 [Z0][VMM][I]: shutdown: Unmapping disk at /var/lib/one/datastores/101/76/mapper/disk.1
Fri Aug 16 11:45:17 2019 [Z0][VMM][I]: shutdown: Umounting disk mapped at /dev/loop0
Fri Aug 16 11:45:17 2019 [Z0][VMM][I]: ExitCode: 0
Fri Aug 16 11:45:17 2019 [Z0][VMM][I]: Successfully execute virtualization driver operation: cancel.
Fri Aug 16 11:45:17 2019 [Z0][VMM][I]: Failed to execute network driver operation: post.
Fri Aug 16 11:45:17 2019 [Z0][VMM][E]: Error deploying virtual machine: fw: -
Fri Aug 16 11:45:17 2019 [Z0][VM][I]: New LCM state is BOOT_FAILURE
