I’ve setup virtual network with:
BRIDGE = "br0"
BRIDGE_TYPE = "linux"
DNS = "192.168.7.1 8.8.8.8"
GATEWAY = "192.168.7.1"
OUTER_VLAN_ID = ""
PHYDEV = ""
SECURITY_GROUPS = "0"
VLAN_ID = ""
VN_MAD = "bridge"
and use ubuntu bionic lxd template vm:
User template
HYPERVISOR = "lxd"
INPUTS_ORDER = ""
LXD_PROFILE = ""
LXD_SECURITY_NESTING = "no"
LXD_SECURITY_PRIVILEGED = "yes"
MEMORY_UNIT_COST = "MB"
SCHED_DS_REQUIREMENTS = "ID=\"0\""
SCHED_REQUIREMENTS = "ID=\"5\""
Template
AUTOMATIC_DS_REQUIREMENTS = "(\"CLUSTERS/ID\" @> 0)"
AUTOMATIC_NIC_REQUIREMENTS = "(\"CLUSTERS/ID\" @> 0)"
AUTOMATIC_REQUIREMENTS = "(CLUSTER_ID = 0) & !(PUBLIC_CLOUD = YES)"
CONTEXT = [
DISK_ID = "1",
ETH0_CONTEXT_FORCE_IPV4 = "",
ETH0_DNS = "192.168.7.1 8.8.8.8",
ETH0_EXTERNAL = "",
ETH0_GATEWAY = "192.168.7.1",
ETH0_GATEWAY6 = "",
ETH0_IP = "",
ETH0_IP6 = "",
ETH0_IP6_PREFIX_LENGTH = "",
ETH0_IP6_ULA = "",
ETH0_MAC = "02:00:e2:ef:27:63",
ETH0_MASK = "",
ETH0_MTU = "",
ETH0_NETWORK = "",
ETH0_SEARCH_DOMAIN = "",
ETH0_VLAN_ID = "",
ETH0_VROUTER_IP = "",
ETH0_VROUTER_IP6 = "",
ETH0_VROUTER_MANAGEMENT = "",
NETWORK = "YES",
SSH_PUBLIC_KEY = "",
TARGET = "hdb" ]
CPU = "1"
DISK = [
ALLOW_ORPHANS = "NO",
CLONE = "YES",
CLONE_TARGET = "SYSTEM",
CLUSTER_ID = "0",
DATASTORE = "default",
DATASTORE_ID = "1",
DEV_PREFIX = "hd",
DISK_ID = "0",
DISK_SNAPSHOT_TOTAL_SIZE = "0",
DISK_TYPE = "FILE",
DRIVER = "raw",
IMAGE = "ubuntu_bionic - LXD",
IMAGE_ID = "1",
IMAGE_STATE = "2",
LN_TARGET = "SYSTEM",
ORIGINAL_SIZE = "1024",
READONLY = "NO",
SAVE = "NO",
SIZE = "1024",
SOURCE = "/var/lib/one//datastores/1/0ef1fb25b7fb4ac301bc287d8ad652fe",
TARGET = "hda",
TM_MAD = "ssh",
TYPE = "FILE" ]
GRAPHICS = [
LISTEN = "0.0.0.0",
PORT = "5920",
TYPE = "VNC" ]
MEMORY = "768"
NIC = [
AR_ID = "0",
BRIDGE = "br0",
BRIDGE_TYPE = "linux",
CLUSTER_ID = "0",
NAME = "NIC0",
NETWORK = "bridge",
NETWORK_ID = "9",
NIC_ID = "0",
SECURITY_GROUPS = "0",
TARGET = "one-20-0",
VN_MAD = "bridge" ]
OS = [
BOOT = "" ]
SECURITY_GROUP_RULE = [
PROTOCOL = "ALL",
RULE_TYPE = "OUTBOUND",
SECURITY_GROUP_ID = "0",
SECURITY_GROUP_NAME = "default" ]
PROTOCOL = "ALL",
RULE_TYPE = "INBOUND",
TEMPLATE_ID = "1"
TM_MAD_SYSTEM = "ssh"
VMID = "20"
But, though it boots, I only get an ipv6 ip address and it doesn’t have an IP in the Info tab so I can’t use VNC.
Ubuntu 18.04.3
lxc --version 3.0.4
Package: opennebula-node-lxd
Version: 5.8.5-1
- Create virtual network template as above. Making sure that the br0 exists and is working.
- Instantiate vm template ubuntu bionic lxd selecting the created virtual network.
- Get the following log:
Mon Nov 4 20:21:56 2019 [Z0][VM][I]: New state is ACTIVE
Mon Nov 4 20:21:56 2019 [Z0][VM][I]: New LCM state is PROLOG
Mon Nov 4 20:22:12 2019 [Z0][VM][I]: New LCM state is BOOT
Mon Nov 4 20:22:12 2019 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/20/deployment.0
Mon Nov 4 20:22:15 2019 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Mon Nov 4 20:22:16 2019 [Z0][VMM][I]: ExitCode: 0
Mon Nov 4 20:22:16 2019 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Mon Nov 4 20:22:27 2019 [Z0][VMM][I]: deploy: Processing disk 0
Mon Nov 4 20:22:27 2019 [Z0][VMM][I]: deploy: Using raw filesystem mapper for /var/lib/one/datastores/0/20/disk.0
Mon Nov 4 20:22:27 2019 [Z0][VMM][I]: deploy: Mapping disk at /var/snap/lxd/common/lxd/storage-pools/default/containers/one-20/rootfs using device /dev/loop11
Mon Nov 4 20:22:27 2019 [Z0][VMM][I]: deploy: Mounting /dev/loop11 at /var/snap/lxd/common/lxd/storage-pools/default/containers/one-20/rootfs
Mon Nov 4 20:22:27 2019 [Z0][VMM][I]: deploy: Mapping disk at /var/lib/one/datastores/0/20/mapper/disk.1 using device /dev/loop12
Mon Nov 4 20:22:27 2019 [Z0][VMM][I]: deploy: Mounting /dev/loop12 at /var/lib/one/datastores/0/20/mapper/disk.1
Mon Nov 4 20:22:27 2019 [Z0][VMM][I]: deploy: --- Starting container ---
Mon Nov 4 20:22:27 2019 [Z0][VMM][I]: ExitCode: 0
Mon Nov 4 20:22:27 2019 [Z0][VMM][I]: Successfully execute virtualization driver operation: deploy.
Mon Nov 4 20:22:27 2019 [Z0][VMM][I]: Successfully execute network driver operation: post.
Mon Nov 4 20:22:28 2019 [Z0][VM][I]: New LCM state is RUNNING
lxc list shows:
| NAME | STATE | IPV4 | IPV6 | TYPE | SNAPSHOTS |
| one-20 | RUNNING | | fd03:66e4:3fc5::e2ff:feef:2763 (eth0) | PERSISTENT | 0 |
The vm should have an ipv4 address.
Other notes:
Looking at the logs in the router (dnsmasq), there is no DHCPREQUEST from that mac, but if I run dhclient inside the vm/container it does a DHCPREQUEST and gets an IP but it still doesn’t show up in the Info or other tabs in sunstone, so I still can’t access VNC.
Thanks for your help.
