Hello everyone,
I use a Ceph datastore as an image repository. The system datastore is localhost and by using TM_MAD as ssh everything is working great. I want to change VM image format from RAW to qcow2 due to the use of incremental backup. In VM template I add DRIVER=qcow2 but it’s still create RAW format (I checked by qemu-img info).
Actually yes, RBD uses RAW disk format, when the VM is deployed it is automatically converted.
The snapshots made in RBD images (for incremental backups) are Ceph-based.
Did you have any problem defining a incremental backup job with a ceph based image?
Hello Bruno
Thank you for your answer. I resolved this problem by creating a new Datastore with qcow2 OS images.
Anyway live incremental backup is not working. When I turned off VM, backup was done. I get the below error:
Error: Error executing ‘virsh --connect qemu:///system backup-begin --reuse-external --backupxml /var/lib/one//datastores/167/814/tmp/backup.xml --checkpointxml /var/lib/one//datastores/167/814/tmp/checkpoint.xml 48b71aba-6b4c-45f4-ba1f-443361995077’: error: Operation not supported: creating checkpoint for incremental backup is not supported yet
